took forever to start
Old 06-02-2013, 06:55 PM
Mr Phil's Avatar
Default took forever to start
okay this is not my usual fuel related issue, I went to turn the car on and the car would not even attempt to crank over it was like the ignition cylinder was bad or something is this a common problem having to attempt to start the car 25 times before the starter finally kicks in
Old 06-02-2013, 08:30 PM
AmnSF's Avatar
Gotta love them gremlins!!
Old 06-02-2013, 10:04 PM
AmDWs6's Avatar
probably your cylinder i guess, try this move the wheel to the bottom left corner more like pressure it and turn it on (keep in mind u might want to lower pressure or raise it), works at a certain point lol
Old 06-02-2013, 11:58 PM
Philip Pugeau's Avatar
battery? alternator?
Old 06-03-2013, 12:00 AM
Mr Phil's Avatar
It wasn't battery issue, there was just no connection at all, I talked to some others and they said vat issues.... which would make sense cuz the security light on the dash stayed on after everything else turned off
Old 06-03-2013, 12:06 AM
yeah, that make sense. haven't had this happen to me. perhaps the starter is failing? what is a VAT issue?
Old 06-03-2013, 02:18 AM
Mr Phil's Avatar
Vehicle anti theft.... I've read that sometimes it goes bad or some **** and will create problems with starting your car.... Idk what triggers iy or how to fix it though
Old 06-04-2013, 08:10 AM
George Fuselier's Avatar
fix here, works on firebird, the guys that put my remote start in did the same thing to fix mine
Quick Reply: took forever to start
