Everyone with SD tune issue: VERY lean on starts after certain time delay.
Who has problems when you start the car and it commands 11:1 and you see 14:1 (just an example)? On warm starts my F****** a/f goes to a damn 20.1:1. This **** is getting old fast. The car runs like *** until it has been driven a little bit. I am about to order a MAF for the car until we can figure out what the issue is. I dont know anything I havent changed for this. Please post up if you have this issue or if you know of any fix. Also what year car you have an OS.
For me: 2000 Stock OS
I've never daily driven in pure SD but i've experminted with no maf/o2's and i've never had a problem with lean startup. I'm willing to bet there is a typo or correction needed somewhere in the tune. Try loading another OS, put it in sd and see what happens on startup. If you have deleted the afterstart enrichment table you could try adding a small value and see if that helps with startup.
i am assuming that you have a WB02 sensor...correct. and this is where you are getting your readings.
Well do you still have your AIR or EGR hooked up if so it is adding clean air to your exhaust and that is what is doing it.
i suppose tell everyone if you have these hooked up to your exhaust.
Louie
Louie
ok its none of this easy stuff you guys are saying, this is a BIG problem for SD tunes, I have been over everything, reloaded the stock OS, ect... HPT and EFI Live forums have like a 6 page post about this, yet there are no answers. My OLFA table is set up fine, only problem is I cant add enrichment at 80*C where the car runs hot. I can get cold start to be ok, still have a 20% error but warm starts are way lean.
Originally Posted by Nick Williams
If you figure it out I would like to know. I have seen the same problem. Simple fix is to just put the MAF back on, tune it, and then forget about it and drive the wheels off it.
Originally Posted by Haans249
I've had the same problem, put all of your afterstart enrichments back to stock....you will want to check out your Idle/startup tables and decay rates. It has nothing to do with the MAF.
Best of Luck!!
Adrian
Best of Luck!!
Adrian
What's your MAP reading at idle when it's doing this?
And what is the value you are running off of in your VE for this idle?
What PW does it show for this idle on your scan log?
Trust me when I say this, it has nothing to do with your MAF, and if your VE table is already dialed in after letting it sit for 5-10 mins, then its not the VE table either.
The problem lies in your idle startup airflow tables, especially at warmer startups. Make sure you look at ALL of the tables in there for airflow correction, and not just Startup Airflow Correction.
Also if I restart my car before it has sat for too long, maybe 5-10 min, it will start fine. Any longer than that it has issues. I know there are soak time corrections for cranking VE but this crap is happening while the car is running and at higher airflow values, the AFR actually comes to where it should.
When I start the car cold in the morning its way lean compaired to commanded, yet when I drive it it will richen up 1-2 points at hgiher airflow. A likely table to fix this looks like the bias correction factor but that doesnt even do anything.
Originally Posted by WS6FirebirdTA00
This is not the problem. My idle ariflow at startup is the same as warm idle. If it is not the MAF then why is it taht everyone can put the MAF on and its fine?
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Best Regards,
Adrian
Adrian
The reason why it does this is there is a parameter in there that will instantly turn off the idle startup airflow corrections once you start driving, this is why you see this happening, which is also another indication to me as to the startup airflows are too high which is causing your lean startups.
Adrian
Adrian
Fact of the matter is, there is some sort of table in there we must not have access to. Like I said, I just started the car, 18.0:1 AFR idling, drove it, got back in the driveway after maybe a 2 min drive and that **** was still 10% lean.
