AES Boost 5.3 shortblock $2599
Old 01-18-2011, 05:57 PM
AES Racing's Avatar
Default AES Boost 5.3 shortblock $2599
I've had many contact me for 5.3 boost shortblock, I listen and here we go.
  • Diamond piston 3.830" bore, -5cc inv. dome dish
  • Total Seal ring set
  • Scat I beam rods, 4340 forged, ARP bolts
  • Factory crankshaft polished and balanced
  • Clevite bearings, durabond cam bearings
  • 5.3 iron block machined and assembled
$2599
Compression ratio using GM MLS gasket
w/ 60cc chamber 10:1
w/ 64cc chamber 9.6:1
w/ 66cc chamber 9.4:1
w/ 68cc chamber 9.2:1
w/ 70cc chamber 9:1
Upgrades,
Scat H beam rods +$100
Total Seal AP top ring +$100
ARP main studs +$188
Aluminum 5.3 block +$200
let me know if you have any questions
Fraser
Old 01-18-2011, 06:04 PM
IT_SS's Avatar
nice!
Old 01-18-2011, 09:05 PM
itsback08's Avatar
interesting..
Old 01-18-2011, 09:41 PM
MH.
MH.'s Avatar
PM Sent...
Old 01-18-2011, 10:58 PM
TurboS10's Avatar
3.9xx bore potential/price
Old 01-18-2011, 11:17 PM
Ericmck2000's Avatar
Hrm, You mean to tell me there is a viable option besides using arp studs?
Old 01-19-2011, 02:03 AM
AES Racing's Avatar
I ran factory main bolts in my APS 402 engine 30k miles, 900ish horsepower. Caps looked fine since I recently tore down the block to check it out.
Theirs guys at that level with stock LS2 and LS3 force induction engines.
Old 01-19-2011, 02:05 AM
AES Racing's Avatar
We're doing 3.830" bore size, force induction you want much cylinder wall possible.
Old 01-19-2011, 06:25 AM
JAX04's Avatar
Nice Fraser
Old 01-19-2011, 08:18 AM
HydroStream6's Avatar
Sounds like a bargain. Nice.
Old 01-19-2011, 08:19 AM
JAX04's Avatar
Fraser, ill send you my address so you can send one ill test the living **** out of it for ya
Old 01-19-2011, 08:24 AM
rotary1307cc's Avatar
very nice!!
Old 01-19-2011, 10:36 AM
Keith's Avatar
You should post this up over on the trucks section if you already haven't.
Old 01-19-2011, 10:38 AM
LS1RedZ's Avatar
Damn thats a very nice price with some nice parts!
Old 01-19-2011, 10:50 AM
If i did it over again i would have gone with a forged aluminum 5.3
their liners are beefy
IIRC, don't the aluminum 5.3 liners share the same OD as the ls6 liners?
Old 01-19-2011, 11:20 AM
gnx7's Avatar
great price for a budget shortblock!
What power levels would you be comfortable rating the I beam and then H beam setups at?
Old 01-19-2011, 12:00 PM
AES Racing's Avatar
I've seen stock LS2 and LS3 engines run out to 800rwhp, being thats a 6 speed corvette figure 12% driveline loss, says 896hp.
I beams are 4340 forged with ARP bolts, i'd say 900hp.
Anything more might as well put our 390ci engine in.
Old 01-19-2011, 12:19 PM
One question... I always thought I beams were better than H beams? But the H beams are the $100 upgrade? I could be wrong.
Old 01-19-2011, 01:24 PM
AES Racing's Avatar
Depends on the style of I beam, the Scat I beams are closer to factory dimension LS rods, i'd say theirs less machine work done to the scat I rods. Oliver rods, Callies etc heavier rod.
Nick at Compstar told me I beams take lot more machining and work to produce. Also figure $1500 I beam set will use a US steel from Trenton Forging, ARP L19 rod bolts too.
Old 01-19-2011, 03:26 PM
N2OBaby's Avatar
Thumbs up
Nice shortblock.
How much with ported 5.3L heads?
Quick Reply: AES Boost 5.3 shortblock $2599
