Gauge needles
Copy & Paste Moderator
Here is someone selling their blue needles:
https://ls1tech.com/forums/parts-cla...e-needles.html
There was a post on here somewhere about using needles from another GM car. If I can find it, i'll post it here.
https://ls1tech.com/forums/appearanc...e-needles.html
You can also use needles from a Oldsmobile Silhouette. I believe I ordered one from a Venture and one from a Silhouette. You will have to swap the black pieces, I broke the black pieces off the needles (very carefully) or if you have a small enough drill bit, that's your best bet. Then I just glued the new needles to the original black pieces. I used a clear adhesive so it wouldn't affect the light. I would post a picture but I sent my cluster out over a month ago to get some stuff done to it and still have not received it back.
I've got like 3 different sets for sale...they are all blue though
https://ls1tech.com/forums/parts-cla...ift-*****.html
I also have a set of these I modified. They are for a silverado. They are shorter than our needles.
http://i.ebayimg.com/00/s/OTA0WDE2MD...pXDGAu/$_1.JPG
Why would you tint them black? That would reduce light output (or make them not light up at all if you go too dark).
If you find them too bright, adjust the **** so the gauges are dimmer.
You're probably thinking of something like VHT Niteshades. Its a black tint for tail lights. I guess it could work. They probably won't be as bright. I'd go light on the coats, maybe 2 light ones. They'll still light up the same color, just black-ish looking during the day.
Heres what clear or "white" needles look like took mine a little farther and installed blue leds just to backlight them getting rid of the blue though and going to red also going to find a way to have the needles calibrate upon start up ive done a few other clusters for people these are pics of mine
Pretty neat, where did you get the clear needles from?
