Bumpstop Mod: my first try at writing an install
Old 12-10-2005, 11:10 AM
Pewterpower's Avatar
Default Bumpstop Mod: my first try at writing an install
This "free" mod will will take the Throttle body blade to 90*, which will result in greater flow and better response than the stock setting,
which is well below 90*.
Tools needed:
*A DREMEL for grinding
*Multimeter
You will be grinding down the bumpstop on the throttle body. This will allow the throttle cable to pull back the blade inside the TB to a full 90*.
It's best to use a voltmeter and monitor the voltage reading from the Throttle Position Sensor. A reading of 4.71 volts is a perfect 90*
and it is critical that you do not grind any further. If you do, your blade will open more than 90* and you will set an SES light. I stopped at
4.69 volts to be on the safe side.
Locate the Throttle Position Sensor (green arrow)
You will be monitoring the BLUE wire (red arrow)
With the key in the ignition, turned on, but not started (engine NOT running) locate the blue wire. If the probe on your voltmeter is thin enough,
you can just jab it into the back of the plug, at the blue wire, and then ground your voltmeter on the chassis somewhere. Otherwise, you can use
a small sized wire (stripped on each end) and jab it into the back of the plug, at the BLUE wire, and then just use your alligator clip from your voltmeter to get a reading. At the idle position, your reading will be about .85 volts.
here's a close up:
Now you can start grinding. I used a dremel, but whatever you want to use is up to you. I've even heard of guys using a file to grind it down
(that sounds like WAY too much work). The Dremel is perfect because it is small and you can move it around to different angles.
This is the actual bumpstop.
You can see where mine has already been ground down.
Again, it's critical that you do not go beyond 4.71 volts, so grind a little down, and check the voltage by pulling back the throttle blade until it
stops on the bumpstop.
Do this as many times as it takes (grind some, then check it....grind some, then check it) until you get to where you want to be. I stopped when I
got a reading of 4.69 volts. That's about as close to 90* as you can get , and still be on the safe side. Be careful that your grinding wheel doesn't
hit the spring (like I did on mine) I just barely hit it, and it left a mark, so it wouldn't take much to cut that spring. Then it will no longer be free mod.
That's it. I definately felt an improvement from the SOTP meter, along with response, and I'm sure you will too.
(Thanks to Ed F. for helping me with this)
Disclaimer: I assume no responsibility if you break something. Do this at your own risk. If you still don't know what your doing,
then find someone who does.
Old 12-10-2005, 11:51 AM
1BADTALS1's Avatar
good read i have yet to do this but i think ima give it a try..i always like the install directions that have great pics thanks much..
this should be added to the sticky...
Old 12-10-2005, 11:59 AM
tbick's Avatar
awesome write up! the pictures make everything really easy to understand. seems like an easy mod to do, i will be doing it shortly.
Old 12-10-2005, 12:07 PM
snake charmer's Avatar
man those are some pretty nice pictures!
Old 12-10-2005, 01:33 PM
WsSickLs6's Avatar
you have sexy hands...
Old 12-10-2005, 02:00 PM
You like those gray hairs? You perv.
Old 12-10-2005, 06:17 PM
fa18007's Avatar
OK, just finished. Stock it was at only 4.18 volts WOT!!! I ground it down to 4.65 volts to be conservative. Only thing is, the gas peddle only lets you go up to 4.48 volts with it all the way to the floor (Yes I even moved the floor mats). So I guess I can't even set the SES light even if I ground the stop all the way off. Oh well. Im gonna go drive it and see how it feels.
Old 12-10-2005, 09:00 PM
Good job...
I guess you'll have to do some monkeying around with your throttle cable then.
Old 12-10-2005, 09:42 PM
bolton98TA's Avatar
is this track tested yett? wonder how much it would help. also is their any way this will hurt the engin?
Old 12-11-2005, 12:51 PM
fa18007's Avatar
Well, i just got back from a test drive after the mod... Wow. Didnt add crazy horsepower, but definatly feel a difference. I did a 5mph-60mph burnout and something new...It kicked sideways punching it at 35 mph. And I have an A4 with 2.73s and good toyos. Well worth it mod.
Old 12-11-2005, 07:38 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
There is no particular voltage that will yield a fully
open TB. For example, when I did mine the WOT
voltage was 4.36 stock, when I got the butterfly
to 90* the voltage was 4.60.
If I remember correctly, a code sets when the
voltage hits 4.75, at least on the 2000 models.
Old 12-11-2005, 09:15 PM
Magnet's Avatar
where do you get the miltimeter thing...can ya rent it from autozone??
Old 12-11-2005, 10:16 PM
Twister's Avatar
Just going to throw this out there.
Shouldn't some reference to the actual Throttle blade be made? Great write up btw. If my sensor is showing 95% throttle opening and my blades are WOT, shouldn't I then look for modifying the actual sensor itself instead of the blade opening?
Old 12-12-2005, 10:13 PM
Your blade will only open as far as your throttle cable will allow it to. From everything I read, the sensor reads 4.71 at 90* which is why I monitor the sensor, and not try to measure the blade itself.
Old 12-13-2005, 03:46 AM
6spd's Avatar
wow that's a beautiful writeup. I'll be doing that this weekend. Definately should be stickied.
Old 12-13-2005, 05:42 AM
Twister's Avatar
Cool, just wanted to throw it out there though. Personally, I would rather (and this is only my point of view) position the blade so WOT was infact WOT, then attack the sensor via the slot method. But I am also going to look into your method write up. BTW, nice write up!
Old 12-13-2005, 06:02 AM
chpmnsws6's Avatar
sears, A-zone, advance auto parts.
they are only 15-30 bux to buy and good to have around
Old 12-13-2005, 06:18 AM
Twister's Avatar
Harbor Freight....3 dollar! Make ya holla!
Old 12-13-2005, 11:37 AM
Crazy Man's Avatar
If you go to far its a easy fix just grind the bumpstop down and drill a hole in it. Tap it and put a small bolt through the hole then you can adjust the bolt in or out. Till you get the right voltage....
Old 12-13-2005, 12:07 PM
Toasty's Avatar
Good write up, it wasn't hard to do at all. My stock voltage was 4.35, now its reading 4.65. WOT feels a bit harder on the punch. Thanks!
Quick Reply: Bumpstop Mod: my first try at writing an install
