Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Cooling: SBC
Old 09-15-2008, 02:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Cooling: SBC
I have a crate SBC in my '51 Merc, has mechanical fan, no shroud. If driving a while it will start to get hot, am wondering if a shroud OR electric puller (or two pullers) would be the best fix? I plan to swap in a carbed LSx in the near future but not right away.
Thanks!
Old 09-15-2008, 03:17 PM
1994Z28Lt1's Avatar
if you plan on going lsx sometime in the future i would go ahead and get a nice dual puller or pusher setup, since you will want that for the lsx anyway
but yeah with no other problems your heating up because you dont have any kind of shroud think of it this way, electricity follows the path of least resistance, with a fan with no shroud, its easier to pull air from just in front of the radiator than it is to actually pull air through the radiator
Old 09-15-2008, 03:48 PM
LS1Tech Co-Founder
Good point.
Old 09-15-2008, 04:37 PM
edcmat-l1's Avatar
Needs a shroud.
Old 09-15-2008, 05:49 PM
slow95z's Avatar
needs e-fans! free up some more ponies and get rid of the manual fan.
Old 09-15-2008, 05:59 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Dual puller setup that is also shrouded. You'll use them later on with the swap, so why half-fix it now just to end up buying the e-fans later.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 09-16-2008, 11:37 AM
LS1Tech Co-Founder
Yeah let me see what I can fit in the way of dual pullers with a shroud, I think stock f-body fans are too wide but we'll check.
Old 09-16-2008, 12:52 PM
6 & 8 Second Club
mrdragster1970's Avatar
Especially since it's while moving, it tells you its probably needs to be sealed. I had a big dodge work truck.
Threw a new engine in & didn't put back the shroud or the blocking from the grill to core support.
The air just went around the sides. As mentioned, less resistance. See if it's possible to seal the front
so the air must go through the radiator. The dodge just had some thick plastic filler panels that were helping direct air flow.
Good luck John.
Quick Reply: Cooling: SBC
