Window motor issue
Window motor issue
I have a 2002 Camaro with what I believe to be a failing driver side window motor. The window moves at a very slow speed, and can only move 3-4 inches at a time without completely stalling. I usually have to wait around 5 minutes for the window to become semi-functional again.
Does this indicate a failing window motor? Or is it something else?
Thank you.
Thank you.
Save the manuals!
BTW - short circuiting the thermal cutoff switch should also be done with disabling the auto-down feature of the window. If not done, the auto-down module will keep the motor energized for a while after its finished its movement, putting additional stress on the motor and door.
Just finished mine today and other than having to do it in the driveway with no shade when its 97 out it was not that bad. The hardest part was lining up the right holes but it just took a few wiggles. I did use longer screws but it wasn't necessary. And don't forget to loctite them! I've been putting this off for a long time but now I'm going to do the pass side. Plus now I have a reason to upgrade the door speakers and add some dynamat..
This worked well for me. I didn't disable the auto-down feature though, I'm just careful to tap the window up slightly after it hits bottom. I think as long as you don't have someone holding down any of the buttons for a long period of time then you shouldn't have a problem.
My driver window motor is out but I remember the nightmare I had on my 96 pass side. My A/V works so I will just deal w it til weather is nicer. More info on this 'shbox' method?? I did the reg pull last time ....thx
honestly, changing the motor was easy. it took longer to pull the panel off and drill out the access holes for the rivets. and if you're going to go thru the trouble to pull the motor out in the first place why not just spend $25 and replace it?
