XM radio....
Old 01-24-2006, 08:42 PM
badtexasZ28's Avatar
Default XM radio....
My first question is....Where does everyone mount their XM receivers? I have the roady 2 and I cant seem to find a good location for it. Any pictures would rock....
second, has anyone had a problem with their stereo being static like? I know it has something to do with the antenna since when I unplug it from the back of the stock head unit the static disappears.
Old 01-25-2006, 05:36 PM
hmmm... i guess no one has the roady 2 in their cars.....
Old 01-25-2006, 06:10 PM
cbrich's Avatar
I don't know on where to mount it your radio.
I guess you are using an FM modulator, I know several people with XM and Sirius, and they all have static on them when use the FM modulator. The only solution I know of is install it using Aux. inputs.
Old 01-25-2006, 06:40 PM
normally i would say you are correct about the FM modulator, but this happens on regular FM channels as well but goes away if i unplug the antenna from the back of the headunit
Old 01-25-2006, 08:52 PM
hlujan's Avatar
are you using the modulator built in the roady 2 ecause those suck you need a direct modulator you'll need 2 antenna adapters if your using the factory stereo a 40 gm10 and a 40 gm 20, now if your getting static when your trying to listen a regular fm sation and getting satic its probably because you have your roady 2 on you need to turn it off to listen to regular radio or it will bleed in no matter what station your tuned to
Old 01-25-2006, 08:55 PM
2K2WS6TA's Avatar
Mine's in a T/A, so I don't know if pics would help, but I put it infront of the shifter, on the plate that has the TCS switch on it,
Heres a pic so you can see what I mean
Old 01-27-2006, 10:37 PM
scrmnss's Avatar
I mounted mine in the same place as 2K2WS6TA i used a piece of sheet metal to mount it. Buy the direct connector from the roady 2 to the radio it is about $70 well worth it. Go to the xm forum to find it.
Old 01-28-2006, 01:25 AM
frisky2101's Avatar
i go the sirius starmate and mounted it directly uabove my Alpine CD player I'll post pics soon
Old 01-28-2006, 07:47 AM
Bill's 02 Z-28 SS's Avatar
HI Folks
don't have a picture but I mounted mine on the center, driver's side AC outlet - this way I don't have to look down.
Bill
Old 01-29-2006, 01:04 PM
Hawk832's Avatar
I have the jvc sirius and the antenna is on the inside dasboard.
Old 01-29-2006, 03:47 PM
j3ff's Avatar
I put mine above the rear view mirror and use the steeringwheel controls to control it.
Old 01-29-2006, 03:49 PM
j3ff's Avatar
for the antenna i routed the wire to the side- down the pillar and put the actual antenna inside where the defrost air comes out of, there is a NICE little square place to put it on. Works very welll!
Old 01-29-2006, 09:28 PM
i like your mounting spot.....wonder if the roady 2 will fit up there
Old 01-30-2006, 06:25 AM
j3ff's Avatar
Yes it will, I had that in the same spot (but a little to the left) untill december.
