eibach springs in front with stock springs out back?
i like the ride height of the front with the eibach springs but i would like to fit a bigger tire out back i was thinking about throwing the stock springs in the rear for now has anyone done this? the car is a full bolton cam car it also has stock shocks
How big of a tire do you want to run in the rear? I run 315's in the rear and the car sits at 26.75 measured from the ground to the top of the fender opening. Plenty of clearance and no rubbing.
Then you might have a problem in the back, but not with tire clearance. The cut springs in the rear probably let the car bottom out way too often which adversely affects handling.
I only cut a little over a half. It has bottomed out a couple times but the car was loaded with people, it hasnt when Im by myself though.
