Aftermarket bump stops for the rear?
Anyone make any ?? Wanted to cut the stockers for a bit but I think i remembering a few people saying there are aftermarket ones available. I only have about 1 inch or so of travel before mine hit but I need them because my drivers side one is deteriorating.
I just installed the energy poly ones and the adapter brackets from Herron Performance which does away with those factory spacers, with this setup the bump stop is apx 1" shorter than the original setup.
First pic shows new energy Jeep poly stops
Second pic shows factory setup w/white foam like bump stop
there was a thread about how jeep bushings fit right in , or may have been with minor modification... or others try and find 3rd gen bump stops, i think i heard they are better quality? anybody correct me...
There was a big long thread on this a couple months ago...
See:
http://www.hawksthirdgenparts.com/bushings_2.aspx
Question I have is: Is it worth converting to the Koni bumpstops that integrate on the shocks??
See:
IMO, running the Koni 55mm or GC soft strut bumpstops on the shock give you more compression travel, and the transition on to the bumpstops is a lot smoother then even the factory Z28 bumpstops.
I've had both the GC and the Koni 55s on the rear Koni SA shocks, and like the GC stops a little better, plus the GC stops are about 1/2 the cost of the Koni 55's.
Are you talking about these? If so, which one, I assume the soft, progressive? You also said strut -- I assume you meant shock version?
http://www.ground-control-store.com/...php/II=10/CA=1
Very cool thanks guys. I dont mind a soft or stock bumps I would probably trim them a bit for more travel. i cant trim the stockers as they are faling apart. The 200 lb rear springs do wonders to keep the suspension from hitting them lowered all the way on GCs with smaller spring isolators
A different shock with a smaller diameter shaft would work better with the Soft progressive shock bumpstop.
