Ajustable torque arm
Old 10-01-2010, 02:38 PM
gothp's Avatar
Default Ajustable torque arm
I run 12.20s w/M6 I bog on my launch and I leave on the rev limiter.
I have a ajustable torque arm set @-3 should i set it to 0 in hopes to get throw the bog? What do the 11 sec. cars do????
Old 10-01-2010, 05:53 PM
bigj2717's Avatar
It should be set at -2
Old 10-01-2010, 07:16 PM
Moderator
jimmyblue's Avatar
If you want to change the bite, you have to move the
nose and not the pumpkin.
Old 10-01-2010, 07:52 PM
BADD SS's Avatar
do you have a video, or can you describe whats happening? Is it bogging off the limiter? what tires? Gears? Need more info....
Old 10-01-2010, 08:12 PM
gothp's Avatar
Everthing is in my sig 27 tire and a 4.11 gear. It pulls the tires then bogs in first gear
no video going to the run the car next wed for the first time in 3 years. I did some tuning on the car. my afr was 11.7 now it will be 12.5-12.8 hope to be in the 11s now!
Old 10-01-2010, 08:33 PM
BADD SS's Avatar
whats the limiter set at?
Probably need less tire or more gear.
whats the 60'
Old 10-01-2010, 10:28 PM
gothp's Avatar
1. 6200 rpm
2. 1.74 60 ft
Old 10-02-2010, 02:24 PM
BADD SS's Avatar
1. 6200 rpm
2. 1.74 60 ft
I would try a 26inch tire, bump the limiter to 6400.
dont leave on the limiter, but just under it.
are you trying to keep it SI or what. A nice cam and you would be out...
FWIW, when I had only 4.11's, slicks, headers and a lid I went 12.20 @112 1.70 60'..
About the same as where youre at..... cheap heads, torqure ii cam some weight reduction and suspension 10.95 @ 125 1.42 60'... Just need more power probably.
Old 10-03-2010, 11:58 AM
gothp's Avatar
Trying to go as fast as i can with SI hoping to be alot faster after the new tune and afr in the right spot. I will try to leave under thr rev limiter next time to the track. Puting my race tires on today and next wed going to the track!!!
Old 10-03-2010, 02:14 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Pinion angle has no effect on traction. For some reason this misinformation has spread throughout the forums. You can change your instant center by positioning the height at the front of the torque arm, allowing you to soften or strengthen the hit to the tires. This is only possible on custom applications or full length torque arms with torque arm relocation crossmembers that allow height adjustment. Pinion angle should be preloaded negative. The amount depends on your power level, the amount of flex in your suspension, and how hard you launch. -2 degrees is a good place to start for most but a car with a manual transmission leaving off the rev limiter can go up to -4 to -5 degrees for the track only. Try not to exceed -3 on the street.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
