Panhard Rod????
Old 05-30-2012, 11:36 AM
MIDNITE Z's Avatar
Question Panhard Rod????
Does BMR sell a non adjustable panhard rod with rod ends? I can't see to find one
Old 05-30-2012, 11:50 AM
lees02WS6's Avatar
No. Why do you need it to be non-adjustable?
Old 05-30-2012, 12:39 PM
Founders Performance's Avatar
We have rod end adjustable panhard rods for around the same price as most companies non adjustable poly versions.
http://www.foundersperformance.com/p...Rod-Style.html
Old 05-30-2012, 12:50 PM
MIDNITE Z's Avatar
On second thought maybe I should get adjustable incase I decide to lower car in the future.
Old 05-30-2012, 01:13 PM
MIDNITE Z's Avatar
Thanks for the link
Old 05-30-2012, 01:19 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
We don't sell a non-adjustable panhard rod with rod ends becasue most customers that use a non-adjustable panhard rod are more budget minded. Your best best would be to just do an adjustable, that way if you need the adjustability down the road you will have it. Give us a call here at the shop and we can take care of you.
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 05-30-2012, 06:01 PM
dabest09's Avatar
Is rod/rod style a bad idea for a daily driver?
Old 05-31-2012, 08:47 AM
BMR Sales2's Avatar
We have plenty of customers who have used a BMR rod ended style panhrad rod on their daily driver so it shouldn't be an issue at all for. I don't think you will see much added noise at all.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 05-31-2012, 08:16 PM
MIDNITE Z's Avatar
What is the difference between the two?
Panhard Rod, DOM, On-car Adjustable, Polyurethane Bushings
Panhard Rod, Chrome Moly, On-car Adjustable, Polyurethane Bushings
Old 06-01-2012, 09:04 AM
BMR Sales2's Avatar
The Chrome Moly panhard rod will be about 2lbs lighter than the DOM panhard rod. Chrome Moly tubing has a higher tensile strength than the DOM so you can use a thinner wall tubing which makes the Chrome Moly part the same strength as the DOM part but a little lighter. Most people honestly just go with DOM becasue the little weight savings generally isnt worth the extra money unless you are looking to save every little bit of weight.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 06-03-2012, 04:29 PM
MIDNITE Z's Avatar
So I need a adjustable panhard if I plan on lowering the car or could I use a non adjustable panhard rod if I lower the car?
Old 06-03-2012, 05:10 PM
BobP's Avatar
Probably, but it depends on your tolerance for noise. In my experience, except for the TA, rod ends end up making noise on both PHBs and LCAs, but I abuse my car at track days so they see the extreme. I've had them last from a couple of years to a couple of months. Who can tell when manufacturing changes are made these days. Check out UMI roto-joints or Spohn pivot joints for a more street friendly compromise that sacrifices little in handling.
You should probably get one with rod ends, see how they last, and then change over to one of the above options if the noise starts driving you nuts.
BobP
Old 06-03-2012, 06:27 PM
lees02WS6's Avatar
If you have wider than stock rear wheels, then an adjustable is the only sensible thing to do.
As for rod ends, as someone once said on ls1tech, if you've got ten rod ends or one, you've got noise. Tolerance varies, you could as suggested switch to a UMI, Spohn or Currie type Johnnie joints if it bugs you.
Old 06-09-2012, 01:02 AM
MIDNITE Z's Avatar
Yes, I have wider than stock rear wheels
Old 06-11-2012, 10:13 AM
BMR Sales2's Avatar
Definitely stick with an adjustable panhard rod then becasue it will allow you to fine tune the tire clearance in the wheel well so you don't have any tires rubbing.
__________________
Glenn ***
Sales Tech
813.986.9302
Quick Reply: Panhard Rod????
