Strano Spings Question
Old 07-10-2012, 01:13 PM
blk97z28's Avatar
Default Strano Spings Question
If I went with strano springs what kind of drop am I looking at? The are listed at 1.25 in drop but I have seen others say they are between 1.25 in and 1.75 in, in real world application. Also they come in white, would it be ok to get them powdercoated gloss black if I wanted?
Devin
Old 07-10-2012, 01:51 PM
z28bryan's Avatar
I don't think I've ever seen anyone report 1.75 on strano springs. His springs are well made by Vogtland and they don't f*** up with their quality control. You WILL see consistent 1.2 inch drops with his springs.
I'm 99% sure Sam doesn't have any spring powerdercoating custom for bling bling applications.
Old 07-10-2012, 03:20 PM
blk97z28's Avatar
Could I powdercoat myself, (actually have a buddy who is dang good at it do it for me)
Old 07-10-2012, 03:25 PM
egott_91's Avatar
Never seen a report of 1.75" drop either. Never seen a report of them sagging either.
As far as getting them powder coated, I don't see why not. You can't see the springs unless you have it jacked up or underneath the car.
Old 07-10-2012, 04:49 PM
99zee's Avatar
You can't see the rears and have to look close to see the fronts. If you don't like the white, just rattle can them. Like stated above, they are dead on consistant.
Old 07-10-2012, 06:19 PM
lsmaxxed's Avatar
stranos are top of the line just got mine on and love em, you cant see the white so dont waste your time painting
Old 07-10-2012, 08:44 PM
blk97z28's Avatar
How you like the springs?
Old 07-10-2012, 08:45 PM
blk97z28's Avatar
Thanks everyone, did know how noticable the white trim was. On the 1.75in drop, I must of read another thread where the OP was confused which in turn confused me.
Old 07-10-2012, 08:59 PM
trans_am7935's Avatar
read this, strait from Strano's website:
-Consistent lowering of ride height, never will you end up 1.75" lower than stock with these springs.
http://www.stranoparts.com/partdetai...=113&ModelID=7
Old 07-10-2012, 09:30 PM
99zee's Avatar
Love them. Totally different car with them and the Koni's. Hope to add the bars soon.
Old 07-10-2012, 09:34 PM
NicB's Avatar
My car came up bout 3/8-1/2" after switching from prokit. Love the stranos
Old 07-10-2012, 10:55 PM
Azar_Hawke's Avatar
This happened to me too. Though I think the rear stayed similar, the front moved up. I don't have that (personally annoying) front rake anymore, it's a very even car.
Old 07-11-2012, 07:42 AM
cowpunk's Avatar
I didn't measure my drop. I was looking for the handling properties of good springs and shocks. That being said, I wish the front was just a little lower with the Strano's.
CP
Old 07-11-2012, 07:57 AM
NicB's Avatar
Agreed. I love the way my car sits and rides now. No more bad hops on the rear from bunps in street
Old 07-11-2012, 09:45 AM
The Scammer Hammer
dr_whigham's Avatar
From all the sigs I see nothing buy Y pipes.... Anyone know how these do with TSP Duals? I tucked the **** out of mine, but am still a bit worried. I'd like these springs for handling and could give a **** about drop. The less drop the better for me.
Old 07-11-2012, 11:13 AM
LS14EVR's Avatar
See Sig..
I have hi flo cats in my Y and I'm fine. There's not a ton of clearance but it's fine. For how these springs perform, it's worth it. I just love the way this car handles now over the standard 1LE package. Should have been like this from the factory.
Old 07-11-2012, 12:31 PM
The Scammer Hammer
dr_whigham's Avatar
Good to know, and I appreciate the reply (even though it's not my thread)
Old 07-11-2012, 12:49 PM
sscamaroburn02's Avatar
I ended up about 1.2 inches lower than stock with my stranos. I am also running TSP duals dumped and I have tucked the duals up pretty tight against the floor. The lowest point is the tips and there is roughly 3/4 coke can. I do scrap but not as much as you would imagine. I know all the dips and bumps in my area and just avoid them. WIth a passenger it does get alot worse. I think I'm gonna turn the tips outward more and gain another 1/4-1/2 inch of clearance.
Car handles fantastic and wouldn't have done anything different.
Old 07-11-2012, 01:11 PM
z28bryan's Avatar
Just because one might be on stock springs doesnt mean they aren't going to scrape. You'll clear the same stuff for the most part. Though anytime your car goes full compression, it's still the same compression limit stock springs or lowering springs. That's defined by your bumpstops. You'll scrape the same stuff a little less but you can still scrape stuff.
I've got stranos and a catted kooks ypipe. It tucks up tight. I do scrape when rolling over big sharp hills a little. Scraped a million times over the staging hump at the local speedway.. I'm ok. Been doing it for years now lol
Old 07-11-2012, 01:14 PM
blk97z28's Avatar
Could you post any more pics of your car (assuming the one in the sig?) It seems to have actually a nice low look to it.
Quick Reply: Strano Spings Question
