Anyone running the BMR 1" drop A-arms?
My T/A is dying to be lowered, but I'm not sure which way I want to go.
I had a 99 SS with bmr lowering springs and the ride was absolutely AWFUL. And that was before I got to VA. My T/A rides like a Cadillac compared to that car and the roads here still beat the s*** out of the car. So I'm trying to avoid losing any shock rate and ride quality.
I saw the BMR arms and thought that would be a good way to go, but I haven't seen anyone running them, and I just heard from someone else that they really make the ride worse. Can anyone else attest to this?
LS1Tech Premium Sponsor
Depending on what shocks you use with our lowering springs will really make a big difference in the ride quality you have so if you used our springs with factory or cheap OEM replacement shocks than I wouldn't be too surprised about the bad ride quality.
You shouldn't notice much difference in ride quality when using our BMR 1" lowering a-arms (AA020) versus the factory lower a-arms. The fact that our a-arms utilize poly bushings and rod ends make them a little more prone to transfer noise into the chassis but generally it is very, very minimal. I honestly can't think of situation when someone was complaining about the ride quality with our lower a-arms no matter what version they had.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Honestly, I thought the same thing as well. I should also note this was from a guy who heard from another guy who may or may not have a clue what he's talking about. The one thing that I have heard with some consistency is that they tend to increase the bump steer and it is "highly recommended" that you get a kit from somewhere else that I can't currently remember.
The biggest thing here is that my only experience with a lowered car was the SS, so I'm really not sure what the best way to go is.
I actually bought the car with the mods already done to it, but right after I posted this I got to thinking that he never listed shocks being upgraded so I can assume that all that was done was the springs.
Generally for someone in your situation I would recommend our BMR lowering springs (SP001) along with a good set of shocks like Bilsteins or Konis. I know that you can only go off what you have experienced in the past and your previous experience with lowering springs wasn't a good one but I think it was more of an issue with mediocre shocks than the lowering springs themselves.
Maybe see if you can find someone local to you that has a good quality set of lowering springs with good shocks and see if they can take you for a ride so you can see what the car should really feel like.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
If you are only going to be running our BMR 1" drop lowering a-arms than you won't have to worry about bump steer at all but if you run them in conjunction with lowering springs that is a different story. Once you start lowering the car substantially is when you have to worry about bump steer but in your case it won't be an issue.
Kyle, again Thank you for your help. It was a pleasure talking to you on Friday. Looking forward to the Springs.
OP- I have Bilstein Shocks and I'm getting ready to install the BMR Lowering Springs. Once I have them on, I can give you feedback on the ride quality, good, bad, or indifferent.
And this is why I went with BMR....
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Yeah, I think I'm going to have to just pull the trigger on a set and see what happens. I haven't really found anyone in the area with the whole setup, mostly just springs on the decarbons.
Appreciate all the input, though! And I'd definitely like to hear how the ride is after the install!
I have the bmr lowering a arms on my b4c with bilsteins and stock springs. I have hotchkis springs with Kyb agx shocks and tubular non lowering a arms on my 02 z28. I feel ride comfort goes to the hotchkis springs, but the lowering a arms feel much better than other lowering setups I've rode in.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
