separaing control arm help
Old 06-22-2014, 07:33 PM
GTOdave's Avatar
Default separaing control arm help
Hey guys i need some help. My bushing on my control arm to frame squeaks and creaks every bump or little stone. I have everythig i need apart to get the control arm out just need some advice how to get control armseparated from the back of the hub. I have a pic, just some advice how to separate it would be great.
Thanks guys, gtodave
Old 06-22-2014, 08:08 PM
Undertow74's Avatar
Control arm from the back of the hub? Do you mean separating the ball joints on the control arm from the spindle???..... Just take out the cotter pin and take off castle nut and then just put a piece of wood on the top of the stud and hit it out with a hammer, you don't want to mushroom the top otherwise won't get the nut back on after.
Old 06-22-2014, 08:19 PM
GTOdave's Avatar
Heres the pic. I wanna remove that from the back of the hub..but need some advice
Old 06-22-2014, 08:43 PM
fleetmgr's Avatar
Get a large prybar, and pry down on the control arm. At the same time, give the spindle a couple good whacks with a BFH, it should pop right out.
Old 06-23-2014, 08:59 AM
It's not mine! woo hoo!
demonspeed's Avatar
Yup -- that's all that it should take
Old 06-23-2014, 09:28 AM
GTOdave's Avatar
Cool guys thanks..have any suggestions on what bushing to put back in? Im just replacing the control arm to frame bushing. .and maybe a trick to getting the old one out..
Old 06-23-2014, 10:48 AM
demonspeed's Avatar
Here's my opinion: https://ls1tech.com/forums/suspensio...w-experts.html
There are various theories -- choose what works best for you
Old 06-24-2014, 06:15 AM
GTOdave's Avatar
Well guys wasnt the control arm bushing...was the sway bar to frame bushing. The bushing wasnt originally put on right and the sway bar itself was rubbing on the frame..easy fix!
Quick Reply: separaing control arm help
