BMR LCA Relocation Brackets
Weld-on Relocation Brackets?
Or
Bolt-on Relocation Brackets?
Which one do most of you recommend
My car is getting lowered with Pro-kit so i need to buy a set of relocation brackets
Or
Moderator
Bolt-ins; you can find them used, and you can
sell them for what you paid if you change your
mind, go back to stock, get a 12-bolt later, etc.
They are plenty solid and they work, and you
also can't install them at the wrong angle -
unlike weld-ins.
unlike weld-ins.
I forgot to throw in there a question about
BMR's PANHARD ROD RELOCATION KIT for the Upper Rod
I have gmmg catback and when it was installed it was rubbing the upper rod alittle and i had to adjust it alittle and now I am wondering that when I lower my car will it rubber again because the body of the car dropped?
Originally Posted by 2w0s060
You can get a better deal then bmr on the weld in brackets if you look around.
https://ls1tech.com/forums/road-racing/182253-rearwheel-steering-eliminated.html
