what ROTOR SIZE for 18 WHEELS
i've got a 2001 Trans AM and i'm putting 18 wheels on it. so what size and WHATS A GOOD ROTOR? would it be an improvement to change over to a C5 set up?
Copy & Paste Moderator
Unless you're racing, I'd suggest solid rotors. Slots will tear through pads quickly and holes will crack. 13"s are probably all you need. You don't want to add too much rotating mass/unsprung weight.
Restricted User
Originally Posted by ShowstoppaTransAm
why would the drilled or slotted be good for racing but not DD?
So simply decide for yourself if you want the absolute best rotors for your car (plain), or if you want the best looking rotors that still work very well (drilled and/or slotted).
The stock ls1 brake calipers and rotor size are more than capable of handling the job. C5 brakes might stop a little better, but also add more weight to the car. If you got some brembo blanks and a good pad with good racing fluid, you'd be in good shape. Brembo blanks are pretty cheap, around 60-70 per rotor.
Restricted User
About the LS1 brakes...i've come to the conclusion that it depends on your driving. If you are so level headed that you never are tempted to cross the 100mph barrier, or do it so rarely that you are not concerned about being able to stop from speeds like that, then just put on a good set of LS1 rotors and maybe Hawk HPS pads and be done with it.
At sub 100mph speeds, the LS1 brakes are as good as anything else really. However, I find it hard to believe that any LS1 owner doesn't find themselves in a bit of highway-based-rate-of-acceleration comparison on at least a monthly basis. I found myself in one such situation last fall, an endeavor which ended at about 140mph when I noticed that the glorious lack of traffic was permeated by one little neon, about 1/4 mile ahead, in my lane. He was probably doing about 70mph, i was doing about double that speed, so needless to say he was coming up very fast. I didn't have enough lead on the terminator in the other lane to get over safely, so I went to hit the brakes. Nothing. The LS1 brakes are utterly useless at that speed. My only option was to downshift and that I did. It wasn't until about 90mph that I regained some braking power. I didn't really even get very close to the neon, but it was enough for me to decide that better rotors and pads just weren't going to cut it. Thus i'm doing an all-out conversion. Granted that's just me, I can't live with a deficiency like that in my car. Others could probably dismiss it as not being designed for that sort of use. I can't.
But anyway, that's just one point of view to explain the usefulness of all out brake swaps.
I agree. My brakes are by no means scary for normal driving. After hot lapping the 1/4 mile for a bit trapping 118 (so figure hit maybe 125 by the time I was on the brakes?), they started to fade very noticeably and actually got to the point where I felt that if I was not downshifting I would've been in some serious trouble.
The C5 brakes will lessen my acceleration slightly, but I can deal with that for the fade-resistance. My only real issue with them is that I can't put real front runners on my car for the track
