need help with cam swap
Old 08-03-2009, 06:14 PM
2fasst83's Avatar
Default need help with cam swap
i have a 2001 ram air and i am swapping out cam it is a a4 with a 2800 stall. i have pacesetter lt and 3 inch true duals. 4.10 gears full bolt on a 228r cam on a 114. i got a good deal on a 236/242 .580 .590 on a 112. do in need to go to a bigger stall to go with this cam or will it be fine. i have a great tuner that tune my car. thanks in advance.
Old 08-03-2009, 06:27 PM
Rob's 02 SS's Avatar
What brand stall is it? If yank ima say yeah.If vig oytu mite get lucky
Old 08-03-2009, 06:35 PM
BETTER THAN YOU's Avatar
it would be tought but you might get lucky
Old 08-03-2009, 06:38 PM
if i am correct the 228r is 228/224 .588 .588 right?
Old 08-03-2009, 06:45 PM
Deerhunter-Z28's Avatar
It's really up to you, it will drive better and run better times with a bigger stall. Depends on what your goals are man.
Old 08-03-2009, 07:23 PM
2fasst83's Avatar
well the car ran 8.0s in the eight with 3.23 mac mids and slp loudmouth and 228r and the 2800 stall. i am hoping to get it in to the 7.65 range with the 4.10s, lts and true duals and new cam. what do ya guys think.
Old 08-03-2009, 07:38 PM
2fasst83's Avatar
ttt........
Old 08-03-2009, 07:40 PM
What track were you at? Post the whole slip, looks like a turd though from the information you've given.
Old 08-03-2009, 07:47 PM
2fasst83's Avatar
pretty much it was at kennedale. car has never 60 ft worth a damm. i think the best 60 ft was a 1.92. an i just changed for a bmr non adjustable tq to an adjustable random tech tq and set pinion angle at -2. i have lca and ce rear drag shocks set at 50/50.
Old 08-03-2009, 07:54 PM
I don't know much about that track, but I think it's a decent track to run at from what I remember. I was just thinking you might have been at one of those high elevation tracks in west texas. It should have 60ft better than that to be honest. Get a good converter with that cam or you will just have a turd with a bigger cam.
I went 7.32 @ 93 bolt on only w/ a pt4400 1.52 60ft. You should at least be in the 7.30-7.50 range cam only.
Old 08-03-2009, 08:18 PM
2fasst83's Avatar
thank you so much sir. i was think of going to a yank pt4000
Old 08-03-2009, 10:17 PM
beedo's Avatar
Looking to part ways with the 2800????
