Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Determining wire size for 230v welder outlet in garage.... again
Old 07-01-2006, 12:24 AM
99.9percenter's Avatar
Default Determining wire size for 230v welder outlet in garage.... again
What size wires for 120 amp draw?
Old 07-01-2006, 01:23 PM
2xLS1's Avatar
What kind of welder draws 120 amps at 230 volts? That sounds really high.
Old 07-01-2006, 01:54 PM
04gtoBMXracer's Avatar
i would run some 6-3 just to be safe if its within 25 feet of the panel you could just use 8-3 its a little cheaper
Old 07-01-2006, 02:04 PM
Silver LT's Avatar
#2 THHN would work, #1 THHN would be better (3 conductors, plus a #6 ground). "Wiring a House (for Pros, by Pros), by Rex Caldwell, is a good book to get for your wiring need.
For those who wonder, big TIG machines, like a sycrowave 350, can pull 120 amp, 240 volts.
Old 07-01-2006, 03:40 PM
RedZ99's Avatar
wires THW,THHW, TW FOR A TIP WORK AREA, UN-AC'd: #1 for 120A. i just pulled out a quick guide and looked. ground prob as Silver LT says. If you have a industrial electrical supply house nearby, just get one of their catalogs for future ref. Usually, the formula tables are reprinted in the back pages of a lot of them. catalog usually free.
Old 07-01-2006, 08:41 PM
leonpiper69's Avatar
maybe he's referring to a welder that WELDS up to 120 amp?????
Old 07-02-2006, 07:11 AM
My old dinosaur welder puts out 450amps.
Old 07-02-2006, 05:37 PM
JPMuscle's Avatar
I went to home depot and it was the only stuff available was the 3wire exterior stuff i think it was good to 100 amps. My Iron Man 210 only pulls 50amps or so maybe even less. The problem is that this wire is ******* expensive, like 2.99 a foot I think, If your talking the stuff for more amperage get ready to pay out the *** for it.
-john
Old 07-03-2006, 06:10 AM
cbrich's Avatar
For a 200 amp service, my dad (master electrician) only uses 2/0 or 1/0 depends on the run, for a 100 amp service #2 or larger.
Quick Reply: Determining wire size for 230v welder outlet in garage.... again
