drag radial as front tires
Old 12-19-2013, 08:32 AM
crw3673's Avatar
Default drag radial as front tires
Was looking at tires for my camaro and was wondering if i could use mickey thompson et street radial II, front and rear on car. These tires would be use for daily driving, only in dry weather. Sizes 265/40/18 front and 305/35/19 rear. http://www.mickeythompsontires.com/s...StreetRadialII On slp corvette rims 18 x 9.5 front and 19 x 11 rear. http://image.vetteweb.com/f/tech/vem...vette_rims.jpg
Old 12-19-2013, 08:40 AM
RandallBlackwell's Avatar
I would not recommend running those on the front. look into Nitto NT01 or NT05
http://www.nittotire.com/tire/nt01
http://www.nittotire.com/tire/nt05
Old 12-19-2013, 09:46 AM
RAMPANT's Avatar
Good lord no!!!!!!!
A really bad idea.
Those drag radials have extremely loose side walls. I could not even stand them on the rear of my car on the street with a 555R II on the front.
Buy a proper street tire for the front and run the DR on the rear only. That is how they are designed.
If you want them to match, look a regular NT05 for the front and a DR NT05R for the rear. Tread patterns are very similar.
Old 12-19-2013, 11:40 AM
Raoul-Duke's Avatar
lmfaooooo Whyyyy??!!!
Old 12-19-2013, 12:31 PM
Rise of the Phoenix's Avatar
I run Mickey Thompson ET Street Radials on the rear and Nexan 3000 tires on the front. Find a different tire for the fronts.
Old 12-19-2013, 03:58 PM
Firebirdmuscle's Avatar
Yeah, that not a good idea op. I your wanting to match when your tires now wear out is do the nt05 front an nt05r for the rear
Old 12-20-2013, 12:09 AM
SScootin98's Avatar
M/T has a new street comp tire
http://www.mickeythompsontires.com/s...tem=StreetComp
Old 12-20-2013, 08:28 AM
04qsgtoMA's Avatar
NItto NT01. Ran them on my GTo front and rear. Talk about grip on all 4 corners.
Old 12-20-2013, 10:23 PM
JDEP162's Avatar
I wud have to say run regular performance tires in front man. MTs every 5k miles is expensive enough 2 at a time, let alone 4
Old 12-21-2013, 12:58 AM
camar0corey's Avatar
A vote from me for BF Goodrich Sport Comp 2s. I love these tires!
Old 12-21-2013, 01:24 AM
Latch's Avatar
The question is why would you even consider it?
Quick Reply: drag radial as front tires
