How to Fit 315's
How to Fit 315's
ok i want to get 315's on my car and was wondering all i have to do to fit em' on. Also where to get all of this done to fit em' on, and if the place where i buy the tires at will do it for me?
thanks
david
thanks
david
Mine bolted on with no clearance issues whatsoever, 17x11 wheel with a 50mm offset and your good to go. My car is at stock height though, some of the guys on here say an adjustable Panhard rod in necessary for a lowered car.
Absolutely no need to cut the bump stop off entirely. I never touched mine. Just couldn't let the rear axle hang for a tire change. No biggie.
Removing the BS will allow your rear axle to travle too far upwards, increasing the risk of the tire contacting the wheel well, and damage to your shocks.
I have a set of 315/30/18 bfg's on c6 rims on my 02 ws6. stock ride height and i had to hammer alot of the inner fender wells to get the to fit without rubbing. ajdustable panhard helped a little but much hammering was involved and i cut off the bump stops. i still have on more spot to hammer as i noticed when i was at the track this weekend and pulling the wheels off the ground, the tires rubbed one little spot on the side. good luck
Jon
Jon
Lift the car from the rear diff. and you don't have to cut your bump stops. Lifting from there will keep your rear sus. from drooping, and you can install your wheels with no problems.
Originally Posted by mycamaroSS
dude manny I LOVE UR SS, and ur license plate lol
Thanks man...it's a Z28 though with a Suncoast SS hood, and that license plate is photoshopped, I have the real deal though in the mean time, just have to take some pics of it!
Manny
Post this again, and you will get a time out.
THIS ISSUE WILL NOT BE DISCUSSED!
Just because you feel it is acceptable to completely disregard manufactures recommendations, does not make it advisable.
Xsta Z 28
Xsta Z 28
