Autolite Engineer Provides Good Details on Spark Plugs
By -
Spark Plug Close
Lots of people like to share their information on spark plugs online, but many of them are wrong. Engine Labs cuts through the b.s.
Unless you race a vehicle with diesel power, the odds are good that at some point, you have had to select the appropriate spark plugs for your high-performance engine. If you weren’t sure which plugs were right for your build, you likely turned to some online resource for help, but with so much misinformation on spark plugs being shared online, there is a good chance what you think that you know is wrong.
To help address the lack of knowledge on spark plugs, the crew at Engine Labs sat down with Jerry Reeves, Director of Engineers for Autolite, to get the accurate low-down on the pulse of our engines.
Pre-Ignition vs. Detonation
The first information detailed in the original article looks at the differences between pre-ignition and detonation. Pre-ignition is generally caused by an ignition source in the cylinder, such as the ground strap on an extended-nose spark plug while detonation is caused without an ignition source – typically happening when internal cylinder temperatures get too high.
Detonation can be caused by a lean tune or crappy fuel while pre-ignition is often caused by using the wrong type of spark plug for your given application.
Heat Range
Some people believe that heat range varies by the style of electrode or the material used to construct the plug, but heat range is determined by the length the ceramic insulator around the electrode. A hot plug has more ceramic, so the spark has to travel further to escape the plug and that creates more heat, while a shorter ceramic sleeve leads to a cooler plug.
Two Spark Plugs
Cold plugs are generally better for high performance applications, as they produce less internal heat and they often have a shorter ground strap – leading to less occurrences of pre-ignition.
Fine-Wire Plugs
Some people believe that newer, fine-wire plugs tend to be hotter, but that is not the case. The size of the electrode has no measurable impact on the plugs heat range, but there is a performance advantage to the fine-wire design.
The thin, often iridium-coated electrodes require less voltage to create a spark, so running fine-wire plugs can produce less of a load on your ignition system. These thin wires are coated in precious metals to improve durability, but the Autolite exec stressed that this doesn’t cause a significant amount of extra heat in the engine. Most importantly, these plugs don’t get hot enough to cause pre-ignition.
Fine Wire Plugs
There is also the belief that a copper-core, thick-electrode plug will do a better job of burning off excessive gases and carbon deposits, but that is dependent purely on the heat range. The thickness of the electrode or what it is coated it has no impact on heat range, thus those factors have no impact on how well the plug burns off unwanted carbon and gases.
Which Plug for You?
If you are building an engine that will spend lots of time in routine driving situations, like idling in traffic or cruising at low engine speed, a hotter plug is a good idea. This will generally reduce engine emissions while also knocking out any excessive carbon in the combustion chamber. On the other hand, if you are building a high performance engine for racing that already generates a ton of heat, you don’t want to introduce any extra heat to the combustion process – making a cooler plug a good idea.
Group of Plugs
As the original article points out, the many of the differences from one plug to another might improve performance or emission levels, but things like the materials used and the length of the threads don’t have the impact on heat range that some people believe.
Join the LS1tech forums today!
"Before I was old enough to walk, my dad was taking me to various types of racing events, from local drag racing to the Daytona 500," says Patrick Rall, a lifetime automotive expert, diehard Dodge fan, and respected auto journalist for over 10 years. "He owned a repair shop and had a variety of performance cars when I was young, but by the time I was 16, he was ready to build me my first drag car – a 1983 Dodge Mirada that ran low 12s. I spent 10 years traveling around the country, racing with my dad by my side. While we live in different areas of the country, my dad still drag races at 80 years old in the car that he built when I was 16 while I race other vehicles, including my 2017 Dodge Challenger SRT Hellcat and my 1972 Dodge Demon 340.
"Although I went to college for accounting, my time in my dad’s shop growing up allowed me the knowledge to spend time working as a mechanic before getting my accounting degree, at which point I worked in the office of a dealership group. While I was working in the accounting world, I continued racing and taking pictures of cars at the track. Over time, I began showing off those pictures online and that led to my writing.
"Ten years ago, I left the accounting world to become a full-time automotive writer and I am living proof that if you love what you do, you will never “work” a day in your life," adds Rall, who has clocked in time as an auto mechanic, longtime drag racer and now automotive journalist who contributes to nearly a dozen popular auto websites dedicated to fellow enthusiasts.
"I love covering the automotive industry and everything involved with the job. I was fortunate to turn my love of the automotive world into a hobby that led to an exciting career, with my past of working as a mechanic and as an accountant in the automotive world provides me with a unique perspective of the industry.
"My experience drag racing for more than 20 years coupled with a newfound interest in road racing over the past decade allows me to push performance cars to their limit, while my role as a horse stable manager gives me vast experience towing and hauling with all of the newest trucks on the market today.
"Being based on Detroit," says Rall, "I never miss the North American International Auto Show, the Woodward Dream Cruise and Roadkill Nights, along with spending plenty of time raising hell on Detroit's Woodward Avenue with the best muscle car crowd in the world.
Rall can be contacted at QuickMirada@Yahoo.com
