10 Second Club Now you are haulin! 10s are sweet
10.99 @ 122
Old Apr 15, 2010 | 09:28 PM
TA1364's Avatar
Default 10.99 @ 122
Went one 10.99 @ 122.85 before getting kicked out. Car is ms3/125 shot, it needs to be on a dyno pretty bad tho. Only weight out of it is exhaust ends after the Y, spare tire and 15" wheels. Stock tranny, stock rearend.
1.56
7.00@98
10.99@122
Old Apr 16, 2010 | 10:38 AM
smok'nZ's Avatar
MASS seller approved
great time for a budget set up
Old Apr 16, 2010 | 12:28 PM
TA1364's Avatar
Thanks. Theres more in it for sure. Shift points and keeping it out of OD right before the traps should help out.
Old Apr 16, 2010 | 12:46 PM
MATTREDSS's Avatar
Nice time....Congrats!
Old May 7, 2010 | 01:30 AM
stoverz28's Avatar
Is it an A4?
Old May 7, 2010 | 11:38 AM
TA1364's Avatar
Yes A4. Havent sprayed it since, got it on the dyno yesterday and it put down numbers lower than it did with bolt ons. Got to see whats up.
Old May 7, 2010 | 05:44 PM
TheBlueKnight's Avatar
Very nice! What stall and rear tires?
Old May 7, 2010 | 11:39 PM
TA1364's Avatar
Pt4400, ET streets
Old May 8, 2010 | 08:51 AM
MATTREDSS's Avatar
^^^ WTF.......spam
Old May 8, 2010 | 01:41 PM
soul strife's Avatar
Did you run it at Kil-Kare? Nice times.
Old May 8, 2010 | 01:50 PM
BAD-LSX-7's Avatar
put a 150 in it off the line with a slick and do work!
Old May 8, 2010 | 06:45 PM
TA1364's Avatar
Yes at kilkare. I want to get the power I have sorted out first. It went 120mph on the same size shot before the cam swap.
Old May 10, 2010 | 12:14 PM
99corvette's Avatar
Yeah its called breakage of the 10 bolt lol
Old May 10, 2010 | 05:07 PM
TA1364's Avatar
I want to spray off the line but with stock suspension and a not so great track it doesnt hook to well. Maybe if I get slicks it will hook.
Old May 11, 2010 | 12:48 AM
180ls1's Avatar
might be trans slip.
Old May 21, 2010 | 06:23 PM
Mike Comp T/A #57's Avatar
Congrats!
I like Kil-Kare
Old May 26, 2010 | 12:21 AM
blwn_00gt's Avatar
Pt4400, ET streets
congrats on the time.
i thought that stall would be to loose for spray but i see its working quite well for you...
Old May 26, 2010 | 01:55 PM
TA1364's Avatar
It blows through a little bit I think. I am shifting at 6000 and I have to have a 6400 pill in the window switch for the nitrous to stay on.
Old May 26, 2010 | 04:10 PM
BAMALS1's Avatar
Good times for the mods! That's crazy fast on a 10 bolt lol.
Old Jun 3, 2010 | 02:15 PM
blockheadnic's Avatar
Good times Sam.
I need to get off my *** and finish my cam install.
