Finally in the 10's Video and slips
I love this turbo. Went to the track tonight. I had the new QA1 rear shocks on the car set at 5. Lowerd the air pressure in the 315 BFG DR's to 15lbs and lined the car up. Staged. Got on the t-brake, left the line on 3lbs and BAM. My 10 second pass is here. 10.91 @ 131mph.
The track went away as the night progressed. The prep was lacking. I definatley need to get the QA1 coil overs on the front of the car and get some big 'n' littles on the car.
At any rate I have a bonified 10 second street car.
![](https://www.fquick.com/images/vehicles/full/223345400.jpg)
Runs are from left to right. I put the in the scanner backwards.
Here is a link to videos of all but the fisrt 10.91 @ 131 run.
I am finally getting somewhere with the car.
Originally Posted by wickedred
Those tuns were on 17X11 ZR1's with BFG 315 Drag radial's
I ran a 10.72 at 128 with 1.52 60ft time on the exact tire and rim you run. It took me a while to learn how to launch my car, but if you can cut a similar 60ft time I bet you got 10.4x-10.5x at least.
Congrats again.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Thanks.
I am in the process of making some changes to the car in order to make my assualt on the single digit club. New Aerospace drags brakes all around, 15x3.5 & 15x10 Weld Pro Stars, MT 26x4.5 Front Runners & MT 325/50/15 Drag radials, QA1 rear 12 way adjustable shocks, rear frag springs, QA1 Coil overs up front with 300lbs springs, a Mild Steel 10pt cage, and more boost. It's gonna be a while down the road be I will get there.
Thanks. I have been slowly working on the car. I have customers to take care of first. I am looking to make the shop a full time deal.
As for my shop car, it is gonna get an S88 or one of my old 91.5mm turbos. Gonna go big this time around.
Yeah, I have to get the 60ft down to get the ET down. I have the mph to run the numbers. I am hopping that with the new upgrades and leaving the line on the brake under more boost will get me where I want to be. Single digit club here I come.
I finally finished the AeroSpace Brake install and got the new ProStars and MT front runners and DR's on the car. ALso got the QA1 Coil overs on the front of the car. As of right now I have sold te FAST XFI setup and am going back to a stock engine harness and eigther a stock PCM with HPT or an AEM ECU for the tunning. I want my factory gauges back. I am goong to stick with the current eingine setup and turbo setup that the car has now and see what it is made of. I enjoy driving the car to much to make it a full out race car just yet.
![](https://www.fquick.com/images/vehicles/full/223360587.jpg)
![](https://www.fquick.com/images/vehicles/full/223360586.jpg)
Went to the track's Test 'N' Tune last night. I have a slight boost leak around ont of the silicone coupleings only allowing me 8 lbs of boost down th etrack and no boost on the T-brake. I managed a 10.71 1/4 @ 131mph with a 1.76 60'. To beat all the second pass of the night it went 11.1 1/4 @ 134mph with a 1.9 60'. I left it at that. Just figured I would Post an update.
