Could I see 10s with my mods?
Could I see 10s with my mods if I got me some street slicks learn how to drive and maybe bump my 75 shot up t0 100 or 150? If not what will it take
Yeah suspension work like LCA's, subframe connectors, torque arm, front shocks and springs, and some drag radials. You might want to up your shot to a 100 or 150 to get into the 10's with the M6 and do you have a new clutch or the stock clutch?
I have a z06 clutch that is not that old and stock rear. Are front shocks/springs and torque arm really that important. Where you at in MD were you at Mason Dixon on Saturday?
i have a stock motor 98 with a 150 shot i have homemade subframe concectors torque arm and boxed control arms wich i made everything including the torque arm and i ran a best of 12.03 in rodgersville missouri. also i have a timing twister for my n2o.
I would say with almost full suspension(torque arm, panhard, sub frames, lower control arms, and probably some adjustable front shocks), a 150 shot, and a 15" wheel with a 26" et street, et drag, or drag radial it would be possible. I don't think you will do it on the stock rear end however.
I think the other guy means on a lighter wheel like Bogart's or Prostar's. But any kind of stickier tire will help a lot, just to get into the 10's with that setup I think the race weight needs to come down. Just remember the stock rear is not going to take the abuse you want to put it through on sticky tires and a M6 car with nitrous. It will most likely go the first trip down the track.
