10s Cam only w/N2o
10s Cam only w/N2o
1.4277
4.3739
6.7642
102.53
8.8345
117.65
10.6445
121.75
Trex and a 100shot.......... I need 4.11s badly.... 4.56s have to go...
title change please..
4.3739
6.7642
102.53
8.8345
117.65
10.6445
121.75
i ran out of gear at about the 1100ft mark.. my 1000ft mph was 117mph.. i coasted through the traps.. i gotta change to 4.11s soon and i will hit 126 - 128 mph easy..
car ran 11.56 @ 116 mph on motor... only made 2 motor passes that day..
I'd check to see what the timing is on the car, since you have it tuned it may have too much timing to add n20.
Also might want to see what plugs you have and switch to a colder n20 plug.
why go 100 when you can go 150
yea cam and n20 seam to be the best way go go fast on a budget. i hope to trap 116mph cam only and throw a 100-150 shot to get over 126 but less then 130
i have 26" tires and 3.90 with a 6500 shiftpoint
it should be that easy
28 x 10.5 x 15s.. ET DRAGS................. it has alot more in it on motor... i gotta nail down the 60ft and i am still running the stock LS1 intake with crappy SLP LTs....
When you get the 4.11's in, switch to a drag radial. You will be amazed. I have run similar numbers with my cam/bolt-on/N2O car (3.90 gears). I used to run with 27x10.5/15 ET Streets (cheater slicks). My best run with them was a 10.89 @ 126 with a 1.53 60'. I switched to M/T 275/60/15 Drag Radial and have gone 10.48 @ 126 with a 1.40 60'. Thats a lot of time cut off by just switching tires.
If its not too much to ask, could you list your other mods? And what does your car weigh? I'm going to aim for mid 10's in the summer. Have cam only car with 3800 stall now, and a nitrous kit waiting to go on the car. Hoping to make it to 10's. I have quite a bit of weight reduction done too
