347 ci N/A s running 10.xx come on in
I think this would be a very informative Thread to all those wishing to get to the 10s N/A so that others(even me) can get an better idea as what guidelines to fallow. Please to be as informative as possible.
Engine Mods:
Suspension Mods:
Tranny Mods:
Chassis, Rear, Tires Mods:
Weight Reduction:
Thank you all very much.
Engine Mods:
Suspension Mods:
Tranny Mods:
Weight Reduction:
Engine Mods: Cam only & all supporting bolt ons
Suspension Mods: the catalog
Tranny Mods: spec 3+/billet steel flywheel, stock M6
Chassis, Rear, Tires Mods: stock steel driveshaft, Moser 9" w/4.11s & locker, MT drag radial 325/50/15
Weight Reduction: More bolt offs than bolt ons
Engine Mods:Ms3 cam, Stock heads, Ported FAST 90/90, Longtubes
Suspension Mods: Spohn Drag Bar
Tranny Mods:4400 stall
Chassis, Rear, Tires Mods: 4.11's on stock rear with 28x10.5x15 et drags
Weight Reduction:weighs 3375 with me in it
good luck, it is rather easy with the correct combo and good weather
1 Post
Engine Mods: Above a .600 cam, AFR 205 Heads, Custom Pistons, Stock Crank
Suspension Mods: Eibach Springs, KYB Shocks
Tranny Mods: 4L60E Race-Built, 4000 stall Yank PT
Chassis, Rear, Tires Mods: Spool, 26X10.5X15 Slicks
Weight Reduction: Take out everything you can!
LS1Tech Co-Founder
Mine:
Engine Mods:
11:1
TFS 215's
HS rockers
Vengeance 240/244
LS2 intake
Hooker 1.75 headers and shorty duals thru bullets
Suspension Mods:
BMR drag bar
QA1's front, CE 3 ways in back
!front swaybar
Tranny Mods:
T400
Was a Fuddle 4800 8" nitrous converter
Moser 9", spool, 4.10's
28x10.5 ET Drags
Weight Reduction:
raceweight 3350
10.92@122
1.48
Best mph 123
99 in the 1/8th
I put a 5500 converter in it now, and I think the car will go 10.6-10.7 in good air, maybe touch 10.5's in cooler air.
You need to get at or below 3400 to really have a shot to run 10's with stock cubes. 3200 raceweight or less would be great.
Engine Mods:
11:1
TFS 215's
HS rockers
Vengeance 240/244
LS2 intake
Suspension Mods:
BMR drag bar
!front swaybar
Tranny Mods:
T400
28x10.5 ET Drags
Weight Reduction:
raceweight 3350
10.92@122
1.48
Best mph 123
99 in the 1/8th
See inserts above. The best thing to do is figure out your OWN combo. No 2 cars are going to act alike with the same combo. The more research you do, you will find a killer combo and this is how you achieve 10s. And one more thing: Don't listen to other people - make your own choices.
CARTEK Racing
Stock bottom end
CARTEK 4X Heads/Cam
Fast 90/90
EWP
QA1's
BMR K-member, a-arms, PHB, LCA, SFC
Stealth Torque Arm
Spohn Anti-Roll bar
Stock t-56 + CARTEK Clutch
10.32 @ 132 driving to and from the track...
CARTEK 4X Heads/Cam
Fast 90/90
EWP
QA1's
Stealth Torque Arm
Spohn Anti-Roll bar
NOT NECCESSARILY THERE JOHN... My PIG weighs in @ 3740 race weight
my best was 10.68 @ 123MPH on a 1.46 60'
Yes, this is N/A
Here is a list of MODS ....
Engine Mods:
FMS Built 347ci, FAST 90mm Intake with a NW 90mm TB, AFR 225-2.05/1.60, FMS Custom Cam w/ Upgraded Valve Train, FMS-HP Tuning, Fast Toys C.A.I., SVO 30# Injectors, ATI Balancer & TCI Flex Plate, with Royal Purple Fluids
Suspension Mods:
BMR and Madman Suspension Components
Tranny Mods:
FLT Level 5+ with a Yank SS4000Extreme Lockup Converter
3.5" Custom Drive Shaft
Moser 9" with 3.70 Gears
Tires-- Bogart "Bolted R/Ts" with 275/50/15 M/T DR's and Front Runners
Wolfe Racecraft 6-Point Chromoly Bolt-In with Swingouts
Weight Reduction:
LOL....Yeah Right! This PIG weighs in @ 3740
Since then I've made a few more changes.
Now I just need the time to go make some Shake Down passes.
Then.... LSX Shootout
Now.... 5/08
Engine Mods:230/230 cam, Stock 241 heads, stock ls6 intake, full boltons...
Suspension Mods: SFC, LCAs, body mount torque arm, 1" solid Spohn Rear Sway Bar, & 40psi airbag in right rear spring
Tranny Mods:Yank SS4000 stall
Chassis, Rear, Tires Mods: 3.23s on stock rear with 275/50/15 MT Drag Radials
Weight Reduction: weighs 3350 with me in it
Also DA was -70ft...
i thought you had a rear sway bar not a rear drag bar
