Will this get me into Low 12's?
my best, is a 12.97 @ 110 mods in sig.
Here's what will be in by spring- Longtubes, ORY, Ported TB, ported MAF ends, MSD blaster coils, 160 degree stat, SFCs, pulley(s) & some Drag radials.
My LCAs are already in
Not to sound conceited, but i can definately bang gears. should all of this be good for low 12s?
you allready have the mph for low 12s even high 11's after those mods you just got to get that hp to the ground, that 60 ft is killing you need 1.6-7 to get your low 12s, the power is definitely there just not on the launch
thats why your trap speed is so high, when u spin alot off the line u usually have a higher trap speed. You hook up on the line and ur trap will come down a little but the ET will drop that much more. U shed .4 off your 60ft time thats anywhere between .4 and .8 off your ET
Originally Posted by chrs1313
like i said get some slicks or mt drags radials and you got your low 12's or high 11's, shiftin is fine after the launch
If everything works right, i should have a 9inch rear from my friend with 411s, adj LCAS, drag shocks on back, and it hass 15" ET streets.. i wonder what i could run right now with that rear and mods in sig
BTW: heres another video http://videos.streetfire.net/player....A-137D687B267F
