What are your 60 ft times with few mods?
I have a 3500 stall, tr224 cam, lid and bullet muffler in my ws6 vert. It has run a 1.76 60 ft on 275 drag radials ... do you all think there is more in it? If so, how low do you think I could get it to?
i would guess mid to upper 1.6's would be possible with that combo. May try pulling the sway bar to get a little more weight to transfer to the back. Also might play with the air pressure in the tires some, i run about 12-15psi in my et drag radials, but some have better luck with less or more. Hope that helps.
What (brand/ model) stall is it?
i just need a stall bigger than my vig2800
to 60'
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
1.89 is my best with LT, ORY, LM, Lid, Nitto 555Rs... and 1.9 flat consistent!
Best with same mods but LS7 clutch and LS2 aluminum flywheel = high 1.9s and I only got that 2 times from over 15 passes.
I cut a 1.62 sixty foot time on my E/T street radials. Mods are listed in the sig and I cut that with the factory converter spraying it out of the hole. Full race weight as well, 3650 lbs.
