Cold torque
My guess is that if you heated it (the gasket) to 70* by the time you got the head on and bolts started...it would be the same temperature as the head/block.
I'm betting in real world however, the amount of expansion in the aluminum and MLS gasket between 20F and 70F is insignificant. The head is going to heat up to several hundred degrees at operating temperature and everthing will expand by a much greater factor.
