Advanced Engineering Tech For the more hardcore LS1TECH residents
How can I convert my 24x cps to read 3ppr
Old 10-20-2010 | 12:38 AM
Snyper's Avatar
Default How can I convert my 24x cps to read 3ppr
Im trying to get my factory Nissan tach to work and it works the same way as an LS1 tach. signal. The factory LS1 runs off of a "4 cylinder" 4 pulse per revolution signal and the factory nissan tach runs the same way only its a 6 cylinder so it runs off of a 3ppr signal. I know theres a way to get the 24x crankshaft position sensor to read 3ppm if its able to be divided by 8 some how.(Hinson supercars sent me a failed attempt at one of these and the instructions were to hook up a wire to the cps then into my nissan ecu and the unit used a power/ground to power it)
...Does anyone in here have the electronic ability to make a unit that would be able to read the cps/8 to give me the correct ppr to get my tach to work? Ive contacted MSD and a few other places with no luck.
Old 10-22-2010 | 08:17 AM
Pocket's Avatar
Dont change anything related to the crank sensor circuit. The PCM is either set for 24x or 58x and is not adjustable in any way. If a 24x PCM does not receive a 24x signal, your engine will not run at all
However, your tach output value IS adjustable, talk to your tuner
Old 10-22-2010 | 08:56 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
what PCM are you using? You should be able to set up the tach output to whatever you want with EFI Live. We are a dealer if you are interested in purchasing it.
Old 10-22-2010 | 10:47 PM
Snyper's Avatar
I am my tuner. And im using HP tuners. I tried to set it up as a V6 tach and it didn't work.
Old 10-22-2010 | 10:48 PM
Snyper's Avatar
Does anyone know the voltage the tach signal puts out? Maybe that will help. The nissan signal puts out .1-.4v signal and I have to hook it into the #1 coil wire that goes into the nissan ecu to be translated by the CAN network and sent to the tach.
Old 10-23-2010 | 08:24 AM
Pocket's Avatar
Try the booster wire if your output is correct but the tach still doesnt move
Old 10-23-2010 | 12:13 PM
Snyper's Avatar
Booster wire?
Old 10-23-2010 | 01:32 PM
salemetro's Avatar
You might PM CalEditor. He's pretty damned knowledgable, and might be able to help you out. He's in the middle of "scaling" my PCM's fuel gauge output for me, so I can use an '02 PCM to feed the fuel guage in my '98 cluster...a HUGE pain....and definitely NOT a regular "segment swap" to make it work. He's been great to deal with. He probably won't ask you for any $$$, but I'd strongly suggest that you make a donation to his cause in the form of $$$....there are not many people out there that are willing to tackle this kind of stuff.
Just my $.02
Old 10-23-2010 | 04:02 PM
Pocket's Avatar
http://www.lt1swap.com/lsx_tach.htm
You need to bookmark and read over that guy's whole site before you start messing with wiring
Old 10-24-2010 | 04:28 PM
Snyper's Avatar
Ive already wired up the whole car. Everything except the factory Nissan tach works. The Tach doens't get a tradition signal like most other tachs. The signal is sent to a control module then converted into a digital code which is then sent to the gauge.
This is from the FSM
I have to somehow figure out how to get a signal and attach it to the #1 ignition wire and thats how someone is the past has gotten it to work. However trying to get a hold of him has proved completely useless.
Old 10-24-2010 | 05:22 PM
Snyper's Avatar
It seems like if I can get the LS coil signal 5v signal to match what the nissan ECU is looking for that it would work....
Old 02-20-2011 | 09:35 PM
salsee's Avatar
Snyper,
Did you ever get this figured out and get your tach working? I am in the same dilema now with my G. Any help you can offer would be greatly appreciated.
Quick Reply: How can I convert my 24x cps to read 3ppr
