Advanced Engineering Tech For the more hardcore LS1TECH residents
Milling 243 Heads Question
Old Jan 22, 2014 | 02:59 PM
DoggyB22's Avatar
Default Milling 243 Heads Question
So I'm installing a Tick Performance Polluter V1 242/244 | .61x”/.61x” | 112LSA along with ported/polished 243 heads & was going to have them milled. I was wondering what everyone would suggest for milling them & doing some fly cutting?? Thanks...
Old Jan 22, 2014 | 04:56 PM
Sales@Tick's Avatar
Mill them to 58cc.
Cut .060 intake and exhaust.
If you can, grab an adjustable timing set as well and degree the V.1 to a 108 ICL as it has no advance ground into the cam.
This will create an extremely violent power band from 3500-7200rpm with a ton of torque from a big cam.
It will feel like a shot of nitrous comes on at 3500rpm literally.
Old Jan 22, 2014 | 10:21 PM
97camaro383's Avatar
Originally Posted by Martin@Tick
Mill them to 58cc.
How do the polluter v1 and v2 compare?
Old Jan 23, 2014 | 01:17 PM
Sales@Tick's Avatar
V1@.050"
9
53
54
10
V2@.050"
10.5
48.5
57
7
The main issue I had with the V.1 and the reason I designed the V.2 is torque. The V.1 always made great peak HP, but it's torque figures were low. This is due directly to the late IVC event.
This is why the V.1(and V.2) respond so well to added compression. I have started recommending the SNS Stage 3 to all customers who will be running cam only with stock compression. The V.2 and V.1 needs 11.5:1+ to shine due to their IVC events. V.2 can get away with less CR and still make good torque, but the V.1 really needs compression.
Advancing the V.1 and adding compression will totally change it's power curve versus running it with stock compression and installing it dot to dot.
Old Jan 23, 2014 | 10:24 PM
DoggyB22's Avatar
Mill them to 58cc.
Thanks Martin appreciate it. I have a SLP Double-Roller Timing Chain so Ill make sure to adjust it to that! Can't wait to get this cam installed. I plan on adding 100-150 shot to it also
Old Jan 24, 2014 | 10:03 AM
xRaTeD's Avatar
Any way to notch pistons in The car. ?
Old Jan 24, 2014 | 12:38 PM
HOTROD7575's Avatar
i like this.
Old Jan 24, 2014 | 12:46 PM
HOTROD7575's Avatar
Default yes
Mill them to 58cc.
taking mine to BB&T in memphis to have them worked.
Old Jan 24, 2014 | 01:11 PM
Kingc8r's Avatar
7200RPMs on a SBE, damn that's iffy long term. Too hit or miss for me
Who P&P your heads Brandon?
I want to mill my 243's, but I don't know how to flycut and don't have the tools lol
Old Jan 24, 2014 | 03:37 PM
DoggyB22's Avatar
His names David. He lives in San Jose. Works on Porsche professionally but does an amazing job for cheap compared to shops. Ill PM his number. But yea he said its $70 a head to do the milling
Here's a thread of some of his work
https://ls1tech.com/forums/generatio...d-porting.html
