effective compression ratio
"So the big question becomes, how much boost do we gain for X amount of compression? The best method we have found is to calculate the effective compression ratio (ECR) with boost. The problem is that most people use an incorrect formula that says that 14.7psi of boost on a 8.5:1 motor is a 17:1 ECR. So how in the world do people get away with this combination on pump gas? You can't even idle down the street on pump gas on a true 17:1 compression motor. Here's the real formula to use:
sqrt((boost+14.7)/14.7) * CR = ECR
sqrt = square root
boost = psi of boost
CR = static compression ratio of the motor
ECR = effective compression ratio
So our above example gives an ECR of 12.0:1. This makes perfect sense, because 12:1 is considered to be the max safe limit with aluminum heads on pump gas, and 15psi is about as much boost as you can safely run before you at least start losing a significant amount of timing to knock. Of course every motor is different, and no formula is going to be perfect for all combinations, but this one is vastly better than the standard formula (which leaves out the square root)."
any thoughts?
I asked the same question to Bob Keller when a still worked for AiResearch more than forty years ago.
His Answer : Use Air Density x C.R. to get the Dynamic Compression value.
The 1 BAR increase (14.7) is 1.5 if 100% efficient, now DEGRADE this value using temperature in Rankine AND you will find a 1.3-1.35 often with an efficient charge air cooling system.
Thus your 1 Bar with 8:1 would become 10.4 as common.
Lance
He was the first to set world records with a "turbo" SBC, Land Speed Records
This was FORTY FIVE years ago.
I was the first to "turbo" a 351-C in the Ford Pantera (1973)
This was the topic we spoke, the C.R. (dynamic) of an engine when in boost.
We contacted Bob Keller at AiResearch.
His answer is STATED above !
Those here at LS-1 Tech ALWAYS ask "how much boost on what fuel"
THUS the NEED.
Lance
The OP STATED a "general" question WITH QUICK FOUNDATION !
MY ANSWER IS CORRECT with the "limited" a limited (no disregard) QUESTION.
ALL HERE (MOST) HAVE NO RESPECT with the USE of EMPERICAL DATA !
THE LS-TECH SPELL CORRECTION IS ALSO IGNORANT "my loss" AND to ALL MEMBERS ! @ Lance (*!*)
Lance
I use a program by Performance Trends called Engine Analyzer Pro.
I have used the "app" for over thirty five years.
I use this program to "predict" engine performance AND to produce a "build" sheet.
ALL here may "DEMO" this app for a period of time before purchase from PT. (free download)
NEXT S/S, yes I agree with a report of cylinder density.
THIS IS WAY I "spec" a Blower CAM with short inlet duration/MAX exhaust duration.
NOW your statement is OPPOSITE of correct cylinder pressure at TDC and other areas.
MY EAP "model" allows for cylinder pressure measurement at ALL cycle phases.
Examples:
1. The supercharged engine's piston has the MAP pressure (boost) "pushing" the piston down on the induction stroke, a good thing.
2. The TDC piston pressure is MAP/EMAP at "overlap" with respect to Wave Tuning Laws.
3. Density Ratio was NAMED by Bob Keller when at AiReserch (YOUR name of Charge Ratio) over forty years ago AND is accepted by Joe Moore (also AiResearch) my customer. (Smith Systems)
4.When the cylinder is supercharged it will be full of air/fuel (Non GDI) MUCH sooner that a N/A engine with requirement for SHORTER Inlet duration as LATE valve closing will only PUSH OUT the filled cylinder air into the inlet port.
THE BEST Dynamic C.R. "tech" is the Piston thread by DIAN and answered by Joe to SUPPORT your stance.
DID you Jake, anyone, read this thread ?
Lance
