How to Assess Wet Flow in Ported Heads
And when adders like turbos, NOS, etc. are involved, it is easier to turn up the boost rather than get the wet low right. (Of course at the highest levels of competition, everything has to be optimized.)
So that leaves me with the $64 question: "How good is the wet flow of the ported heads in my car?"
I have One Data Point:
I had a set of heads done by a truly gifted engine builder who developed his knowledge by pulling the heads off after every trip to he drag strip to see where the carbon was. He never used a flow bench and thought they were useless. Considering all the discussion of depressions of 120" @ low lift and 15" @ high, it makes making a composite evaluation (and tuning) or a port extremely difficult, whereas reading carbon has the correct depressions, manifolding, etc. CFD may be more akin to carbon reading.
His engines were significantly faster than anyone would expect and a short track engine he built for a local racer was winning every race and getting torn down every race.
He did a set of heads for me. He did 90% of the port work in the area of the valve pocket and spent the majority of effort in the combustion chambers. (Of course what happens there is another area involving flame travel, vortices, etc. which are more or less dictated by spark plug location - Morgan says you have to live with the spark plug location design since it is very difficult to change deficiencies there.)
During cold start, the original heads need a lot of choke. After his magic, they needed almost no choke during cold start.
This could be explained by the mixture becoming richer during cold start. Since the same amount of fuel was introduced in both cases, it seems obvious that a lot of fuel was just laying around and not involved in the combustion process before the heads were ported.
CONCLUSION:
- Improved wet flow will make engine run richer.
- It will also produce more HP for the same CFM port flow numbers.
- VE will be increased.
- And given good wet flow, CFM now merely determines what rpm range the torque will appear.
Bad WF means big gobs of fuel not burned and pass out the exhaust.
IF TRUE, there are 2 potential issues:
1) they slow combustion down requiring more advance (probably true) and
2) could make more HP if more right size fuel droplets could be introduced.
QUESTION while showing pig rich due to unburnt fuel, would further enrichening produce more HP due to more good sized droplets?
RICH could mean 1) bad WF, or 2) good WF actually running rich.
It may also mean mixture tuning should be based on HP and not A/F ratio. In which case bad WF may be indicated when more HP is obtained by running "excessively" rich.
THE PROBLEM: I don't think it is possible to get a canned tune for ported heads, the WF characteristics of which are not known. So how to assess WF? I'm thinking cold start open loop A/F ratio.
I think an exhaust gas analyzer would be required to measure HC in the exhaust.
Improved WF would burn more fuel (AFR becomes richer) and reduce HC's.
HC's might be the critical measurement. (Actually a 5-gas analyzer might reveal a lot more.)
TOPIC: Using 5-gas exhaust gas analyzer to assess ported head wet flow
EDIT: CO may be another useful measurement
For all these years engine builders have worked with flow of "dry" air thru the intake system, and power has increased in great part because of it. However, the true medium flowing thru the ports is a mixture of air and liquid fuel. This A/F (air/fuel) mixture acts differently and responds differently to ports shapes and modifications than the wet A/F mixture. This situation has lead to the seeming contradictory situations where small, low flowing ports produce more power than larger high, flowing ports. This fact flew in the face of the rule of More, if some (air flow) is good More (air flow) must be better! Now the cylinder head ads that had listed massive air flow numbers started changing their heads to "high velocity". The higher velocity was a better answer, but the velocity needed to be harnessed, as not all high velocity heads produce good power. What the higher velocity did was atomize the fuel much better and that resulted in a more burnable mixture in the combustion chamber. Shazam! More power out of the same engine.
The same people also told me wet flow was something they had looked at, learned a few things from, and moved on. Ultimately, competition race engines are not designed around achieving "good" or "bad" wet flow or even the highest dry flow numbers. They are designed with the goal of achieving the fastest ET or lap times. .
CFM hasn't been very important in a long time except for advertising. It's more common to use a flowbench in port development for testing velocities with a pitot tube rather than for testing raw flow numbers. Wet flow testing came along and showed people what certain characteristics in the induction path make for good or bad wet flow, but some say it was a waste of time, and some say they learned a few things to apply to their designs, and never really needed to wet flow a head again. There is something to wet flow characteristics, but wet flow testing doesn't seem to be as common place as it was in the first years since Mondello made it popular.
My personal thoughts are that opinions will vary because A) you have to correctly interpret what you see happening in a wet flow test to gain anything from it rather than recording actual data to tell you if you're going in the right direction or not, B) for some people, wet flow testing might not tell them anything that they didn't already know from observing combustion patterns on the chamber and piston face, and C) due to the nature of racing, you might only develop one type of head (ie Hemi, DRCE, SB2, R07, etc) and once you "fix" that head and get good wet flow characteristics, there's no more need to develop that particular head with wet flow testing.
To tie all this in with your original posts, a CNC program isn't always designed by the vendor you bought them from. Sometimes that work is contracted out and might be done by someone who does value wet flow testing and uses it as part of their development work. I don't think there's really a way to asses the wet flow of your particular heads without testing them though. There are lots of other variables in an engine that can affect the fueling of an engine that wouldn't correlate to wet flow. I wouldn't get too hung up on it.
This is not what my post topic is about.
The topic is you acquire a car with ported heads done by an unknown person and no tune, what tests can be done with engine in car to determine if heads are worth investing money in a thorough tune and more mods? If the porting job was bad, throw a canned tune on the car and forget about it. BUT if the porting was done by a person with expert knowledge, further investment is justified.
I focused on wet flow assuming that the porting job was good enough to NOT go turbulent. If flow goes turbulent, the heads are ruined and wet flow is irrelevant.
Hope that makes sense.
Thanks for the post..
What has evolved is that various rules and practices have been adopted with promote wet flow resulting in an empirical knowledge base. The problem with this is that there is no understanding of why stuff works. And without understanding, advancements are left to chance - throwing stuff on the wall until something sticks. Example: people learn which aftermarket cylinder heads produce the most HP and which should be avoided. Again this is empirical and good enough for people playing catchup. Those at the forefront are discovering the physics.
