SOHC for LS
But, we MUST have 2 spark plugs per cylinder (regulatory).
We have no specific limit on width, but weight is ALWAYS a concern. Any V-8 piston engine in a typical car is narrower than an opposed piston engine in most airplanes.
Cars that used overhead cam V8 engines almost universally use STRUT type front suspension. The strut lets you delete the top A-arm of the car and fit things like super wide overhead cam heads and exhaust. This is why you can fit a tall deck big-block in cars like S197 mustangs without getting out the sawzall.
2) Do NOT need nor want DOHC
3) Not much of an operational history with this
4) No idea what the camshaft drive is
5) I’m not sure that they are even in production
Mercury Marine 4 valve DOHC for LS
Edit: I see not too far up you were posting Ford Mod motor images and working on that, so clearly you got there before I did lol.
I ran an aircraft engine with no valves, cams, etc, AND an impellor in the TAIL
Tony, will your first flight also be out of Romana ?
It has SOHC and 4 valves per cylinder.
0.42:1 reduction gearbox to propeller
Takeoffs power - 1,670 hp (1,245 kW) at 3,000 rpm
War Emergency - 1,710 hp (1,275 kW) at 3,000 rpm, +18 psi boost (66” Hg MAP)
With 100/150 fuel - 1,860 hp on the P-51B airplane, with 75" hg. M.A.P
Specifications:
- Merlin 33: 1,400 horsepower at 3,000 rpm
- Merlin 35: 1,280 horsepower at 3,000 rpm
- Merlin 38: 1,400 horsepower at 3,000 rpm
- Merlin 45: 1,185 horsepower at 3,000 rpm
- Merlin 224: 1,680 horsepower at 3,000 rpm
- Rolls-Royce Merlin R.M. 14S.M. Mk 100 V-12 Engine: 1,645 horsepower at 3,000 rpm
- de Havilland Hornet: Over 2,000 horsepower
- Bore: 5.4 in (137.16 mm)
- Stroke: 6 in (152.4 mm)
- Displacement: 1,649 in³ (27.04 L)
- Power-to-weight ratio: 0.96 hp/lb (1.58 kW/kg) at maximum power
- Fuel: 100-octane gasoline
- Cooling: Liquid-cooled
- Supercharger: Two-stage mechanically-driven supercharger
- Type: 12-cylinder, liquid-cooled, 60° V-type piston engine
Aircraft powered by the Merlin Hawker Hurricane, Supermarine Spitfire, North American P-51, North American F-6, and P-51 Mustang
Rolls Royce MERLIN V-12 piston engine
the hellcat motor has dual plugs, big valves, a super charger, over 700hp, and is available for $17k.
https://parts.moparonlineparts.com/o...ine-68303089ac
you can do a billet block for about $10k
