Advanced Engineering Tech For the more hardcore LS1TECH residents
Valve shrouding
Old Dec 22, 2005 | 10:34 PM
ChucksZ06's Avatar
Default Valve shrouding
We talk a lot about valves being shrouded, as in how close they are to the cylinder walls. I recently cleanup up some combustion chambers and was looking at the distance between the edge of the valve and the combustion chamber/cylinder wall. I did some math and found that a 2.08 valve on an ls2 (4.005) actually sits .016 farther away from the cylinder wall than a 2.00 valve in a stock ls1 head sits from the cylinder wall (with the ls1 bore of 3.893). My point, if any, is that most people will tell you that a 2.08 valve is too big for a 4.000 bore. I wonder if anyone has flowed a 2.08 head on a stock bore ls1 and compared it to a 2.00 valved head with similar ports. I wonder if the loss in flow with the larger valve would be offset by the larger opening which helps the flow? How close to the cylinder wall does the edge of the valve need to be in order for shrouding to make a significant difference in flow?
Old Dec 22, 2005 | 10:55 PM
Beast96Z's Avatar
Alot of it has to do with the valve job. If the person doing the head knows that the large valve heads will be used on a smaller bore, than he can take that into consideration when cutting the valve. I remember a test being done a while back where a porter found that the optimum comprimise on a stock bore was a 2.04 valve. Anything bigger started to have comprimising effects on the flow per the smaller bore. I wouldn't think that a 2.08 valve would be to big at all on a 4" bore. If you figure an increase of roughly .100" on the bore, it seems that a increase of .04" on the valve would only help. JMO anyways.
Old Dec 23, 2005 | 10:53 AM
SStrokerAce's Avatar
Funny I've put a 2.120" valve on a 4" bore.
Sometimes you will not see flow gains on the bench with a larger valve but the increase in curtian area will help you go faster and make more power at higher RPM.
Usually it's the head casting itself that will limit putting a larger valve in the head effectively.
Bret
Old Dec 26, 2005 | 01:33 AM
DavidNJ's Avatar
ET has some flow numbers with different bores and the same valve sizes.
Generally, shrouding is one more thing to look at. It is why a 4.125 bore is better than a 4.0 is better than a 3.9, even if displacement is constant. For power, emissions can be a different story.
On SBCs, people relocate the cylinder to further reduce shrouding.
The size of the bore may be a limiting factor on valve size. However a 2.0 intake and 1.6 exhaust leave .3 or .4 extra room. So adding a tenth or so shouldn't be an issue. However, the port must also be appropriate for the valve size. To large a valve for a given port can be just as bad as too small a valve.
Old Dec 26, 2005 | 05:27 PM
Spinmonster's Avatar
Valve shrouding has to do with the distance to the edge of the combustion chamber on the head itself. If you use a bigger bore then you can open the chamber up to the edge of the bore. On a smaller bore, this is limited.
A ported head that is intended for use on a bigger bore already has an enlarged area around the valve to unshroud it.
Old Dec 26, 2005 | 08:49 PM
ChucksZ06's Avatar
no offense but you just restated the question. What you say is true but obvious. I was opening the chambers up to match the bore when I came up with the question.
Old Dec 27, 2005 | 08:01 AM
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
While AFR is coming out with 225 small bore heads, what about their current or older 225 heads?
Many have used them on small bore motors. We are looking at 4" or 4.125" gasket (to match the chamber) on a 3.905" cylinder.
A side view crossection of that combo has to look a little like a mushroom, yet many have done it. What effects can that have on the big picture?
Old Dec 27, 2005 | 11:51 AM
That might be another place to yank out falacies... the bore and chamber matching each other.
Bret
Old Dec 27, 2005 | 11:55 AM
rjw's Avatar
rjw
Bret
Would you be so kind as to share your views on this?
Thanks
PSI've been working on your Dart heads
Old Dec 27, 2005 | 02:54 PM
ChucksZ06's Avatar
I agree with stroker. I scribed each bore to the cylinder head and it was quite instructive how much variance there was. Sure looked nice when it was all matched up though.
Old Dec 27, 2005 | 08:10 PM
MadBill's Avatar
FWIW, many BBCs have factory-relieved bores adjacent to the intake valve... (and some reworked ones ditto on the exhaust.)
Old Dec 27, 2005 | 10:41 PM
rjw's Avatar
rjw
I've seen that as well. My Dart 225's have chambers that are about .04" wider than the small 3.905" bore. Any recommendations?
Old Dec 28, 2005 | 11:31 AM
white2001s10's Avatar
I wouldn't say that myself.
Yes valve shrouding can reduce flow some, but it's usually in such a limited area that it's insignificant, and not so bad as to negate the increase in valve size. To me it's more important to keep the seat diameter near 90% of the valve diameter. A good porter can shape the throat area adjacent to the shrouding such that the effect of the nearby cylinder wall is minimal.
A lot of flow is directed from the cylinder wall side towards the center of the cylinder anyway, so I don't see a little shrouding being a showstopper.
Old Dec 28, 2005 | 02:49 PM
LSwonderfull's Avatar
This guy has it right. I care more about the bowl not being large enough to support a 2.08 valve than cylinder shrouding. LS6 has water jacket in a critical area for enlarging bowl to meet 90% of valve diameter. This is what holds back a gen III head back and makes 2.02"-2.05" valve more ideal, at least with OEM castings.
Old Dec 28, 2005 | 05:26 PM
airflowdevelop's Avatar
Boy, if it was only this easy. Their is no "automagical" formula to determine if a valve is shrouded. The chamber itself will determine how far you can go. A concave chamber design can stomach less then a convex chamber. As in case with the 241 castings and similar where you have a right angle to deal with, best of luck with any valve.
When working with smaller bores, you are better to try and work with what you have instead of reinventing the wheel. A smaller valve opened farther may be a better approach.
As always stated, and rarely listened too...it's about a little more then just "flow"
Dennis
Old Dec 30, 2005 | 08:18 PM
ChucksZ06's Avatar
Thanks for all the input. This forum is a great place to learn from. We all need to support the sponsers whenever possible. Have a great new year.
Old Dec 31, 2005 | 12:15 PM
You always have great quotes.
Old Dec 31, 2005 | 04:12 PM
Dennis
Dennis would you please go into a little more detail about what you're saying. At first glance it looks like you're saying that with a 241 casting that you get better bias & swirl by using a smaller valve, and kill swirl with the bigger valve. Is this right?
Old Dec 31, 2005 | 09:19 PM
headman's Avatar
I have seen heads flow exceptionally well in some cases, despite the chamber being very close to the valve.
But contrary to what some may expect, the proximity to the cylinder wall can significantly aid flow.
I've seen 20+ cfm go away if the valve was too far away from the cylinder wall.
It is still better for the valve to be, too far away..
than even a little too close to the bore.
Old Jan 2, 2006 | 12:12 PM
Yep..... but it deals more with loading the pressure on the valve equally. The smaller the valve the higher the discharge coef and normally you will dispearse the air/fuel charge more evenly around the valve when you have a higher discharge coef... or so the theory goes.
Bret
