Advanced Engineering Tech For the more hardcore LS1TECH residents
Question About Tuning ITB Manifolds
Old Feb 19, 2006 | 06:03 PM
DavidNJ's Avatar
Default Question About Tuning ITB Manifolds
Do ITB manifolds need sychronization like a Weber carb? Other than ECU programming, what sort of setup do they require?
Thanks,
David
Old Feb 19, 2006 | 06:38 PM
Beast96Z's Avatar
After talking to Harrop about mine, I'm under the impression that you can tune them just like any other set-up, just speed density. No other modifacations should be needed.
Old Feb 19, 2006 | 07:37 PM
DavidNJ's Avatar
The reason I asked, is because of a discussion I was in about ITBs on small block Fords, as used in Cobra replicas. People closer to the action than me indicated that the throttles needed be synchonized like a Weber. A PITA if I recall correctly.
However, this has never been mentioned in LSx ITB discussions. My guess is that they are just miss-enformed, and the problem was simple tuning.
This a comment from this page on Webers (http://www.inglese.com/tech.htm) :
A Weber carburetion system will not be right, unless it's synchronized to ensure that each carburetor is doing exactly the same as the next - the name of the game is perfect cylinder tuning. The synchronization procedure can either be a breeze or a nightmare, depending on whether you have a well-designed linkage system or not. The secret to a good linkage setup is that it must allow independent adjustment of each carburetor without affecting all the rest as you go through the procedure. Here again, if someone tells you they're absolutely impossible to synchronize, you might study his linkage. Chances are, it's incorrect and he's fighting himself. The right components are now available to take this out of the dark ages.
David
Old Feb 19, 2006 | 07:48 PM
Beast96Z's Avatar
With a $3k intake, I would hope all the linkages are properly adjusted and all open to the same place. It would suck to get a intake like that and all the blades opened to a diffrent location. I believe the quality of the Harrop or many of the other brands, like Kinsler/Katech use very top quality parts and have a process were they check to make sure things are aligned properly. When mine comes in, I'll deffinatlly check it. Remember, your only checking for the blades being proprtional on these intakes. No gas to adjust, thank goodness.
Old Feb 19, 2006 | 09:30 PM
MadBill's Avatar
Likely all that might be needed is a feeler gauge check for idle stop throttle blade clearances and verification that both banks commence opening together.
Old Feb 20, 2006 | 02:13 PM
DAPSUPRSLO's Avatar
Beast, are people using map sensors with these or are they going to alpha n? I would think you'd have to go alpha n as there is no common plenum, unless ofcourse you just stick the map sensor underneath one of the throttle bodies in one of the runners and assume all runners are the same but I don't think that would work. Maybe i'm wrong though???
Old Feb 20, 2006 | 05:28 PM
Beast96Z's Avatar
The intake uses all the stock sensors. It looks like it has a "tube" type passage that runs down the center of the intake where it can refrence all the cylinders. The IAC also reads off of the tube.
Old Feb 20, 2006 | 05:37 PM
V8Touring's Avatar
You guys probobly already know about this gizmo but i bought this air gauge thing to syncronize some ITB's that i had to take apart, i'm guessing that the Harrop is all ready set up/adjusted ?
The Harrop ITB's sure do look a very good peice of kit, shame it's so expensive
http://www.racetep.com/weberX.html#websynch
HTH
Andrew
Old Feb 20, 2006 | 06:14 PM
DAPSUPRSLO's Avatar
Cool deal, thanks Beast!
Old Feb 20, 2006 | 10:52 PM
DavidNJ's Avatar
HTH
Andrew
This is where I'm confused. I thought those sync tools are to set the idle on a multi-throat weber setup. Where the idle is also the low speed circuit.
On an EFI ITB, the IAC should handle the idle, and the linkage should be sync'd for part throttle operation.
Old Feb 21, 2006 | 04:40 PM
V8Touring's Avatar
David, have a read of this link for the recomended set up of some BMW M5/3 ITB's, this obviously isn't LSx related but it might be use full info ??
http://home.insightbb.com/~todd.kenyon/throttle.htm
