How DA affects Compression?
anyway.. depends on other weather conditions as humidity and pressure.. but higher = thinner air, for sure...
believe me.. i race @ 8000DAs... running a full second slower and more!
For example a motor at sea level with 10:1 CR needs about 91 octane fuel. If you have a motor at 8,000 DA, could you raise the compression to 11.5:1 and still run 91?
I like to use www.accuweather.com to get all of the information I need. You can check the last 24 hours of weather by the hour.
Example # 1: I've fueled up in Flagstaff AZ at 7,000 + ft., and by the time I got to Phoenix (altitude ~1,500?) the engine was pinging like crazy...
Example # 2: When I was handling the technical aspects of the Players' Ltd./GM Motorsports Showroom Stock series for Camaros and Firebirds in the late eighties, about 10 cars from Calgary (altitude ~ 3,500 ft.) trashed pistons due to detonation at a race in Vancouver (altitude ~ 300 ft.). It was really hot, and it turned out they had all brought their own fuel from home. None of the local racers had any trouble..
An oil patch dictum is: "Don't ship fuel downhill."
A jet transport that cruises at 650 mph (true A/S) at altitude would have trouble going that fast near sea level.
A higher DA, or less dense air causes less drag on the airplane or the car for the same True A/S, so you get some gains from high DA, especially at higher speeds on the strip. Pro Stocks aren't that much slower in Denver.
