Advatages of an equal bore/stroke motor?
lets break it down a little: a cylinder is 4 inches in diameter and 4inches deep (given a 0 deck). now why would that have any special meaning besides the 4x4. isnt essentially a numerically square cylinder. now wht does that mean.
It depends on what kind of driving you do. Street, road and Drag with an auto. trans. wants torque and Drag, F1, etc. with multi-speed manual trans. wants peak HP and a narrow powerband. Heavy car = torque, Light car = narrow powerband, high gearing = torque, low gearing = narrow powerband, etc.
A lot of things affect the performance, but generally this is what you see.
The advantage of the biger bore, smaller stroke combination is that you can get more effective valve area and the engine will make more power at a higher RPM.
A few modern high-end race engines go against what you said, QC.
FWIW Bore/Stroke ratio or "B/S" is an easy way to define the amount of over or under-square.
ProStock has a B/S =1.3
Nextel Cup B/S = 1.28
F1 has a B/S = 2.45 (sometimes called "hyper square")
P/S does run in anger in the top 20% of it's rpm range.
Cup plate engines run in anger in the top 0.04% of their rpm range, but short-track/road course unrestricted engines operate in the top 50% of their range, with the same Bore and Stroke.
F1 engines have a fairly large rpm range, about 45-50% of their 20,000 max rpm even with a 2.45 B/S.
In many cases builders use the largest bore allowed by the rules or which fits in the engine, and adjust the stroke to get the displacement they need or are limited to by the rules. B/S ratio then is the result of design parameters, not a primary objective of the design.
Of course there are special cases like the last 3 years in the Engine Masters Challenge, which was a LOT about minimizing and living with detonation.
In engine design it is the combination of every parameter that makes the engine perform. You really can't look at one parameter like B/S without taking into account everything else. It's a juggling act, and many of us can only juggle 1 or 2 ***** at a time rather than 10 or 20.
My $.02
because from where im sitting, it looks like both that 3.75" stroke motor and that 4.125" stroke motor... spin to the same max RPM.... so theres no disadvantage to the destroking... (piston rocking in the bore aside...)
basiclly, go for the biggest bore you can... then stroke it as much as you can.. then put the best flowing heads you can get your hands on...... maybe a bit oversimplfied and brutal.. but when there are no rules, ive never heard a good reason why not...?
"You can't beat inches in any ol' hole."
You're right, as long as there is no CI limit, you go with the biggest bore and stroke that is physically safe to run.
If you've got 2 engine combo's with the same size bore, the bigger CI combo will make more power.
F1 engines are a special case. Almost all racing engines (where intake restrictors, rev limiters, gearing, etc. are not mandated) are rpm limited by the valve train with the valve spring in particular. F1 engines, because they use a pneumatic valve return system(pvrs) are rpm limited by the piston speed. In their case, to maintain reasonable piston velocities and 20k rpm, the stroke is reduced quite a bit and the bore enlarged to obtain the required displacement- hence the hypersquare result.
Pro Stock engines rev higher than Cup engines, and P/S would have a larger b/s ratio than they currently do if they were allowed to run a bore spacing greater than 4.900". With a 4.900 bore spacing, if you bore a cylinder to 4.900 it will beak out into its neighboring cylinder. A 4.800 bore leaves .100 between the cylinders. P/S physically cant increase b/s any more unless the rules are changed to allow block with a greater bore spacing.
Al
Edit- Oops fixed the post. Sorry about that Jon and Bret.
That was the old man Jon aka OldSStroker talking there.
The statment about cylinder burn efficency and it's effect on emissions is the key to why so many motors today are made undersquare in production, or in the now defunct unlimited compression Engine Masters competition.
Bret
Bores over 4.6 inches (ProStock) can still have effective combustion at 10,000 rpm, and bores over 3.8 inches (F1) @ 20,000.
does this solve the problem? what happens when these two flame fronts collide in the middle? or more what im thinking.... when they're both heading towards each other, does the air in the middle get super compressed and ignite? with two plugs, wouldnt you endup running less advance timing?
Al
Al
You may have read that Jason Line fairly recently said that inertia loads were limiting their PS max rpm. Effectively NHRA can cap PS rpm with minimum part weights and materials. Unfortunately it doesn't make it less costly. Redesign of the pistons and especially rods to redistribute the mass can be some help. I'm not privy to what they are actually twisting now, but I suspect it's a few hundred rpm more every year.
The guy I know is going about 10,200 at the finish line.
Al
