Advanced Engineering Tech For the more hardcore LS1TECH residents
Nice intake manifold... - The ITB thread
Old Nov 20, 2006 | 10:53 PM
  #81
Jeremiah's Avatar
Originally Posted by 30thta436
They fit under the cowl of an Fbody fine. I have test fitted one. It will be on and tuned next week.
Im looking forward to the final conclusion on this build!
Old Nov 21, 2006 | 02:41 PM
  #82
TAQuickness's Avatar
What are y'all doing for the upper radiator support on Fbod's?
Old Nov 21, 2006 | 04:37 PM
  #83
Beast96Z's Avatar
I'll be using the polished BMR support, or something of that nature.
Old Nov 21, 2006 | 06:11 PM
  #84
Bink's Avatar
Originally Posted by J-Rod
Update.
I found out that Sam is also doing his own ITB manifold now. Its a cast unit with lots of neat features. I don't have pics yet. But I hear its pretty slick.
Any more info on this? Thanks!!
Old Nov 22, 2006 | 10:15 AM
  #85
Bink's Avatar
Here is some pics of it with our air filter solution.
Slick!!!!
Any updates??
Old Nov 22, 2006 | 08:26 PM
  #86
30thta436's Avatar
Here is some pics of it on the car. It is just sitting there not bolted down. I have to do a little clearance work on the filter covers. They are hitting the valve cover spacers. No big deal, I just have to trim them up a little.
Old Nov 22, 2006 | 08:34 PM
  #87
11 Bravo's Avatar
I like the filter setup. Are you gonna try to get cold air to it? I don't see how it's possible without the Harrop type enclosure losing some hp. Maybe using the cowl somehow.
Old Nov 22, 2006 | 08:49 PM
  #88
30thta436's Avatar
I don't think that will be an issue once it is moving. The enclosures that harrop has really knocks the power out of the intake. The car has a mecham hood on it. So it has air blowing in the engine bay from the raim air hood. It also has heat extractors in the hood which are right over the filters. So hopefully between the two it will be ok.
We will see.
Old Nov 22, 2006 | 10:08 PM
  #89
Big-DEN's Avatar
Alot of us with open element carb filters found they could actually make more power
than a enclosure with two tubes to it.
If they are not getting enough air under movement, a properly designed cowl hood will create a high pressure area forcing air under the hood...
He's going to be straight.
Some of us where concerned with the air filter being so close to the "bell mouth entry" and would've preferered the filter 2" away or so, by way so of some "spacer".
Is all I was saying,
Its going to make power thats for sure.
With that much money on the intake, I would not doubt that my guy had his heads flowed with the intake off and with the intake on to show how little the intake knocks off the flow...
Old Nov 23, 2006 | 01:16 AM
  #90
30thta436's Avatar
I plan on tuning it with the filters on it. But I will take them off for the final run to see what the difference is. If it is big I will look at extending the area between the filter and tubes.
Old Nov 23, 2006 | 01:19 AM
  #91
Big-DEN's Avatar
Our thought of need for a "cowl hood" won't be necessary on the dyno since the hood will be up and the car stationary.
Thats a good idea.
You are attacking it scientifically and correctly.
Old Nov 23, 2006 | 02:37 AM
  #92
30thta436's Avatar
It won't test for a cowl hood, but will show if a volume of space is needed between the filter and the plate.
One step at a time.
Old Nov 23, 2006 | 07:13 AM
  #93
30th - Did you have any clearance issues with the KR sensors, oil pressure sensor, etc.. Is there any wiring that had to be extended?
Old Nov 23, 2006 | 07:16 AM
  #94
ls1408cp's Avatar
So how many people make intakes like this? hartrop, kinser, hockey,and sam is making one also I cant spell
Old Nov 23, 2006 | 07:51 AM
  #95
JL ws-6's Avatar
Race your car!
Being that you are putting that intake on a t/a, maybe a meecham hood with the 4 heat extractor ports would help.. they supposedly allow air to move more freely thru the engine bay, probably help get cooler air in the engine bay. Just a thought.
I do like the filter setup.. but I think with ET heads, or any other head with a raised lip for the valve cover to clear big rockers... the clearance would be more of a problem then you are seeing.
Old Nov 23, 2006 | 08:43 AM
  #96
Big-DEN's Avatar
Supposedly heat extractor hoods "dont work"
Cowl hoods do work, and its not by letting hot air out the engine bay thru the cowl.
Its by creating a high pressure area at the windshield, and air is going to want to go thru the cowl into the engine bay.
Old Nov 23, 2006 | 09:17 AM
  #97
30thta436's Avatar
It appears to clear all of the sensors. The intake is just sitting there. I have not hooked up the wiring, but it looks like all of the wiring will plug in just fine.
If you notice in the pictures there are valve cover spacers on there to clear the Jesel rockers.
Old Nov 23, 2006 | 09:27 AM
  #98
Beast96Z's Avatar
I need to get off my ***.
Old Nov 23, 2006 | 10:37 AM
  #99
JL ws-6's Avatar
Race your car!
I see them now... my bad for not seeing them before. I assume the intake was designed for stock valvecover height?
I have head about the heat extractor hoods not working.. but I've seen one on a car, and believe me, when the radiator fan turns on, lots of hot air comes out fo the extractors..... and I'm sure air comes out of there when the car is moving... that being said I think they work, at least for removing under hood heat.
Old Nov 23, 2006 | 10:51 AM
  #100
Big-DEN's Avatar
QUestion when car is moving, do air want to move "in" the "heat extractor vents or "out".
I believe you when the car is setting still that radiator fan air is going to want to push air out.
When the car is moving is it lower pressure under the hood than "outside" and air wants to go "in" the vents. Or is it higher pressure under the hood than "outside" and air wants to go "out" of the vents.
