Advanced Engineering Tech For the more hardcore LS1TECH residents
Nice intake manifold... - The ITB thread
Old Aug 30, 2006 | 05:40 AM
CATransam's Avatar
Default Nice intake manifold... - The ITB thread
it looks a lot like the Harrop manifold (just without the 8 TB's)
http://www.harrop.com.au/root_folder...fd7022-00.html
Old Aug 30, 2006 | 08:07 AM
MrDude_1's Avatar
if by "alike" you mean they both have 8 runners... yes.
otherwise... uhh.... huh?
Old Aug 30, 2006 | 10:35 AM
FieroZ34's Avatar
I am completely shocked by Harrop's injector placement. Why not put the injectors at the top of the runner? Yes, it'll idle like crap. But it's going to idle like crap because they are ITBs, and if the owner dropped the money for that manifold, there's no saying how radical the heads/cam package is, so that's going to make it idle like crap anyways. And yes, the low end will not be as smooth. But I don't think that's an issue with 600 lift cams and 350cfm heads.
The farther away from the head the injectors are, the more power they'll make. That's why F1 puts them in the damn airbox. That being said, that thing looks SICK.
Old Aug 30, 2006 | 05:19 PM
Beast96Z's Avatar
I don't agree. I own one of these intakes, and the injectors are placed at the same location of the stock intake. The injector mist is so fine, I don't see were it would matter. As for idle, a ITB intake will idle 100,000 times better than a single TB intake. You can have the nastiest of cams with this intake and let your granny drive it to the grocery store. Individual runners gives each cylinder it's own atmosphere, thus all but eliminating cross cylinder contamination and vastly improving driveability. Top-end or low- end, it's all better. F1 cars are completly diffrent from LSX motors, so I see no comparison. If you tried to put 8 injectors in a LS1 air box, I guaruntee you, you'd be lucky if the car cranked. In australia, where these intakes are made, 240* duration cams and 106 LSA's are normal in 346's with these intakes. Idles smooth and drives great.
Old Aug 30, 2006 | 05:37 PM
FASTFATBOY's Avatar
Hehe, I'm starting to wonder the same thing. Basically, weight. About 2800lbs with every option, and an all-iron V6. Not to mention traction, I cut consistent 1.6 60's with just 240hp
A friend has a STREET Fiero that runs low tens on drag radials, turbo 4.3 in the rear, factory wheels...ultimate sleeper.
David
Old Aug 30, 2006 | 07:14 PM
FieroZ34's Avatar
It's been shown time and time again, the farther away they are, the more power they'll make. But on a street car, the effects are sometimes worse than the gains, depending on the owner.
I never said the ITB will idle like crap solely because it's an ITB. I said it' idle like crap because we can assume the operator also has trick heads/cams. And while your's may be smooth, there's no way in hell it is as smooth as stock, and at the stock RPM with that cam. I just don't believe it. Also, if the injector is placed before the throttle plate, your idle and low RPM response is going to totally suck. In this case even a stock head/cam LS1 won't idle below 1500rpm.
I was exagerrating when I said put them in the airbox. You'd obviously have to direct them into the runner, but the injector is still above even the velocity stack. This is not optimal in a street car, as we can't idle at 7000rpm. Thus IMHO the best location is right after the plate, but still as far up the tract as possible. This is how mine are, and I'm not going on a whole "It must be good becuase I have it" thing, but I did a lot of research so that when I dropped $1500 for my ITB intake, it was the best that it could be.
I wish my Fiero ran low 10s.
Old Aug 30, 2006 | 08:27 PM
Beast96Z's Avatar
I didn't say it would be smooth as stock, but for a givin a large camshaft with a very tight LSA, it's already been shown that the car will idle like a much smaller cam. Something like a 24x/24x 106 LSA will idle somewhere around a 224/224 112 LSA. These aren't exact figures obviouslly, but more a comparison. There are plenty of ITB posts/threads running around, and even a few videos of these big cam cars idleing/reving.
Trust me, when I went looking for a intake to feed my motor, I researched, called, bugged, and the researched somemore before I handed over $3400 for mine. I've never been a product pimp, and I don't plan to start now. If it works, I'll tell you, if it don't, I'll tell you.
Old Aug 31, 2006 | 12:15 AM
DavidNJ's Avatar
Mr. Beast, has that been on a dyno? Was that a hydraulic roller or solid roller?
Old Aug 31, 2006 | 02:45 AM
CATransam's Avatar
I beleive that the injectors for F-1 are actualy direct cylinder injection, and from everything I have studied on them (injector location specificaly) the injector should be located as close to the combustion chamber as possible that way when you atomize the fuel it does not have a chance to recondence before cumbustion occurs. This will give you a much better mixture with the air in the system. If you place it farther away, you run the risk of the fuel condencing in the runners and you do not get the full amount of fuel, you get rivers of fuel running into the engine unmixed. This can have all kinds of undesireable concequences.
Old Aug 31, 2006 | 02:47 AM
CATransam's Avatar
i concede , what I actualy intended to say was that it reminded me of the harrop (due to having the individual runners).
Old Aug 31, 2006 | 11:09 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
FieroZ34 you comments on the Harrop intake are incorrect.
The intake actually improves idle quality far over that of a shared plenum intake. I know folks who have built ITB setups with the injectors up top, and down low. There are benfits and drawbacks to each.
The Harrop intake show about a 40 hp gain over a FAST intake especially in the midrange. Also on any ITB intake you have the option to "tune" runner length.
I can show you videos of cars both on the dyno and in car of ITB setups, and eren with what we'd consider a MONSTER cam here in the states it idles like stock.
You have to understand some basics about how an ITB works. This has been covered in other threads. This post sums it up...
Originally Posted by racer7088
The independent runner stuff with the small independent throttles before each port with the constantly pressurized near 100 kpa "mega plenum of the world" above those same little throttle bodies are just less affected by the exhaust reversion that affects a plenum car worse since the whole intake system on these setups is at very low pressure and the exhaust is at such a higher pressure. The exhaust reversion can and does fill up the whole plenum behind the central TB or carb and the whole runner of each cylinder with exhaust diluted air that causes the repeated and erratic misfiring that we hear as the cool loping sound some people love so much.
With enough overlap the IR systems will also lope too and turn black under those cute little throttle bodies from idling with all the same vacuum under them when they are closed and idling but they have less of the total runner to become as contaminated since the higher pressure is close at hand right above them and in the rest of the runner. You will sometimes, with really big cams in these systems see the exhaust and regular reversion in the form of standoff above the runners with some of them at lower engine speeds.
Also when you crack the throttle instead of an entire manifold plenum having to pressurize up slowly instead, now the port sees full atmosheric pressure and density basically almost instantaneously so the throttle response is WAY better. In fact some people need a progressive linkage or it's too jerky for them! Also just realize that Australians ARE crazy and they all drive cars with blowers and NOS and have mohawks. They also like cubic inches in a lot of their racing and RWD but that's finally coming back to the USA too as people here have had their fill of the FWD crap.
Here are pics of both setups.
Now, here is the Harrop C5R setup
Old Aug 31, 2006 | 11:22 AM
Sharpe's Avatar
Originally Posted by cary et performance
there are various different port combinations. One does not fit all. That particular one is for a 400 inch 2200-2400hp blower combo.
I couldn't take it anymore. I had to get off right there.
I'll read the rest later.
Old Aug 31, 2006 | 12:57 PM
777's Avatar
777
WOW, as if the first one posted wasn't good enough.
Old Aug 31, 2006 | 04:52 PM
billybob77036's Avatar
On that Harrop C5r, how large are the tb's? I know they offer them on the normal intake in the 54 and 58mm size (IIRC), did they enlarge them any for this version? With the new LSx blocks coming out that will allow 500"+ I can't wait to see the intake market play catch up with itb setups.
Old Aug 31, 2006 | 05:37 PM
Beast96Z's Avatar
The Harrop intake like I have, or the normal LS1 version, has a 52mm or a 55mm option. I would imagine that the C5-R stuff is built to suit. At over $10k a pop, they better be.
Old Aug 31, 2006 | 11:13 PM
FieroZ34's Avatar
First of all, MY GOD those look amazing.
Please send me the dyno videos, I'd LOVE to see them. Either link them, or my email is AaronZ34@gmail.com (10mb max, sry).
I know there are benefits and drawbacks to both, and I know how they work. But I highly doubt these idle anywhere near what a stock one does. I'd think the Harrop intake would (With the stock heads/cam/etc), but with those huge cams and such in it, I just don't think it could. I'd be interested in hearing the intake you posted, with the injectors right outside of the velocity stacks, idle.
Thanks for posting those, now PLEASE, elaborate on them! More pics, dyno sheets, AND videos!!!
Old Aug 31, 2006 | 11:47 PM
Nickn20's Avatar
you guys are missing something like 6 bolts per cylinder....... hehe.
Old Aug 31, 2006 | 11:56 PM
DONAIMIAN's Avatar
J-rods post is all the motovation I need to finish college, lol.
Old Sep 1, 2006 | 07:32 AM
JL ws-6's Avatar
Race your car!
damn... that open injector setup is nutty LOL. I wonder how bad that engine bay stinks like fuel LOL.
I'd love to put one of those on my car.. btu with zero way of filtering the incoming air I dont' think it would be a really good idea for any street use at all. But it sure would catch some attenion at a carshow.. imagine walking by a 4th gen transam and seeign that under the hood.. you couldn't get people away from the car with a fire hose.
Old Sep 1, 2006 | 08:12 AM
FieroZ34's Avatar
I bet it doesn't stink like fuel at all. The injectors still spray into the runner, not into the airbox. Also, the incoming air is filtered. One of the pics above shows the carbon fiber airbox.
And yes, they are beautiful. Sorry, that'd be an insult. They are drop dead gorgeous.
