Advanced Engineering Tech For the more hardcore LS1TECH residents
need piston help
Old Sep 24, 2006 | 10:02 PM
1MEANGTO's Avatar
Default need piston help
I have a 408 that I'm building. I have a 4.00 eagle crank a 2002 6.0 iron block scat 6.125 rods tsp stage 1.5 ls6 heads. I am trying to get to 13:1 compression is there a piston out there to accomplish this or do I need to special order them? This engine will be a E85 moter when its done. I have been looking for high compression lsx's but haven't seen many around here is there a reason that no one runs high compression on a ls1? Oh this will be a spray baby also.
Old Sep 25, 2006 | 09:53 AM
SStrokerAce's Avatar
How small are your chambers?
Bret
Old Sep 25, 2006 | 10:21 AM
SLED28's Avatar
I can oder you a nice beefy set of pistons from Ross or Diamond and I'll figure out all the specs for you to get it at 13:1.
Old Sep 25, 2006 | 01:06 PM
MUSTANGEATER's Avatar
Just use this.
http://www.rosspistons.com/calculator.php
or
http://www.csgnetwork.com/compcalc.html
Assuming you have a 4.030 Bore X 4.00 Stroke and 61 CC Chambers you're going to need a small dome piston to accomplish this. Most off the shelf pistons will net you somewhere in the mid 12's.
Old Sep 25, 2006 | 09:53 PM
1MEANGTO's Avatar
I found that +10 cc dome pistons from diamond with my 59 cc heads will bring me to 13.2:1 Thanks for the help guys.
Old Sep 25, 2006 | 10:39 PM
That's what I was going to say.... might not be best for detonation resistance though.
Bret
Old Sep 26, 2006 | 01:26 PM
gun5l1ng3r's Avatar
Why would it be bad for detonation?
Old Sep 26, 2006 | 04:36 PM
TT632's Avatar
You should be in pretty good shape using E85 from a CR standpoint. It has twice the Latent Heat of Vaporization as 100% gas. But of course it is also dependant on DCR. Good luck.
Old Sep 26, 2006 | 06:08 PM
A lot of it has to do with flame travel, and the combustion process.
On E-85 I wouldn't be too worried though.
Old Sep 26, 2006 | 11:32 PM
1MEANGTO's Avatar
Well on my 346 the E85 vs 92 pump gas was quite the power differance. I've been seeing alot of 14.5:1 e85 engines I think 13.2 should be pretty conservative.
Old Sep 27, 2006 | 09:58 AM
TT632's Avatar
Must be nice living in a state that has that choice at the pump. Freedom from imported oil and imported cars! We only have 3 stations that I'm aware of in the state that carry E85. I hear California has only a few. So much for them being so progressive!
Have you thought about using alcohol in place of your gas in your nitrous system?
Old Sep 27, 2006 | 08:14 PM
1MEANGTO's Avatar
Well I have been told that the alcohol will wreck the O-rings in the noids. In fact I have expieranced that already with only a 10% mix of ethanol. It seams to swell the o-rings and the noid stays partially open. Well I had a problem with the Cold fusion but never the NX.
