Advanced Engineering Tech For the more hardcore LS1TECH residents
MAP higher at idle than at part throttle
Old Sep 25, 2006 | 08:09 AM
GuitsBoy's Avatar
Default MAP higher at idle than at part throttle
What is the science behind this?
My car idles at an average of 57 kpa at idle at 800 rpm. If I rev it up to 1500 or so, I notice the KPA goes down to 40 kpa. I can understand why MAP dips below idle during decel, not I cant see why it would happen when freely holding revs. I would think that when you crack teh throttle open with yoru right foot, more air enters the intake causing greater MAP readings. The greater manifold pressure is what puts more air into the intake runners and into each cylinder, spinning up the motor. Why do I see the oppodite happen to a point? More air in the intake manifold does indeed spin the motor up, but the lower MAP reading is the confusing issue.
Im thinking that this accel dip in MAP readings may be the cause or atleast contribute to low load cam bucking.
Any knowledge on this?
Old Sep 25, 2006 | 03:52 PM
MrDude_1's Avatar
it happens to any car with a decent size cam in it.
at low RPMs, the engine isnt very efficient anymore... so you open it up with more air (higher MAP reading) and it holds that RPM....
but at a cruise of say, 2500 RPM, its now MUCH more efficient then it was at 800... and you hold a lower MAP reading when maintaining RPM..
remember, its still more air at 2500...the RPM is higher..its just at a different pressure.
make sense?
Old Sep 26, 2006 | 02:25 PM
12secSS's Avatar
Basically, at low rpms the engine is not producing good vacuum which drives a MAP sensor. As you reach higher RPMs (to a point) the engine is now producing better vacuum due to the air flow being at optimum point of the cam (idle wise).
Old Sep 26, 2006 | 02:52 PM
jimmyblue's Avatar
Moderator
The overlap lets it draw back from the exhaust as well as
intake and this decreases the vacuum draw from the intake
side on the intake stroke of the cycle. Because the piston
is slow the cylinder can be filled with a large proportion of
spent gas rather than intake air, even though the overlap
is largely at low lifts. More RPM cuts the overlap actual time
down, less drawn from the exhaust in the early going and
more from the intake as the valve opens.
Old Sep 28, 2006 | 10:23 PM
RednGold86Z's Avatar
IVC is very important too. It's pushing charge back out of the cylinder at lower RPMs until IVC, which goes directly into manifold air pressure, thus raising MAP reading.
Old Oct 6, 2006 | 02:08 PM
ninobrn99's Avatar
ive been wondering this same thing. glad to have an answer on it!!
Old Oct 7, 2006 | 09:46 PM
Adrenaline_Z's Avatar
I think some of you are misunderstanding the question based on this line:
The MAP sensor changes from idle to light throttle, to loaded throttle has very little to do with the cam, but more related to engine load and RPM.
This is what should happen with no load with any camshaft profile.
The pressure in the manifold is relative to ambient atmospheric pressure.
With the engine off, the MAP should read atmospheric pressure because the
pistons are not altering the plenum pressure.
When you start the motor, the pistons create a lower pressure in the intake
manifold which causes air to move from outside of the motor into the cylinders.
At this point the MAP will read lower pressure within the intake manifold than
it had when the engine was off.
The air is moving from high pressure (ambient outside pressure) to low pressure (engine intake manifold pressure).
If your intake had a higher pressure, the air would be pushed out of the intake
and into the atmosphere.
Engine load will alter the piston speed and change the pressure in the manifold.
The intake manifold will have a different pressure while idle at 2000 RPM than it
would at 2000 RPM in gear, going up hill.
It's actually the amount of charge the enters the cylinders that would have
the impact of accelerating the motor. The manifold pressure is not the gauge
of VE%
Old Sep 16, 2021 | 12:18 AM
DOXTER1965's Avatar
Default Map sensor fuction
of VE%
The map sensor should almost mirror the throttle position sensor. As TPS values increase as accelerator pedal depressed this true for the MAP values to increase. Since Map reference voltage gives the PCM needed input to control injector pulse and fuel volume. If the Map sensor for any reason shows a higher intake pressure than true intake pressure a rich or lean condition engine may be hard start, rough idle, poor acceleration, and bad throttle response, will set DTC`s. This may not set a map DTC but others like P0054 Bank 1 sensor 2 heater circuit, P0171 bank 1 lean condition, and P0300, P0302 and so on. Volumetric Efficiency has nothing to do with the 14.7 fuel ratio control. So yes you do have a issue that needs more in depth scanning and component and circuit testing. And Map sensor is a good learner course.
Old Sep 16, 2021 | 12:27 AM
Adrenaline 7 hasn't been here for FIFTEEN YEARS. Really expect him to see this???
