Valve Overlap Limits For Daily Driver
I suggest you get some good professional cam design help to achieve as many of your goals as possible. OEM cams do what you mentioned, but you are probably looking for more torque/power. Everything is a compromise in cam design, and every engine combination is unique.
FWIW, I've seen cams with negative overlap @ .050 make tons of torque and power. It's the entire combination that matters.
He may share some cam spec information with you...perhaps not. Folks who have preconceived notions (lots of them garnered from poor info on the internet) about what cam specs should be often try to second guess the cam guy's specs. You are buying performance, not specs!
Be prepared to tell your cam guy everything abnout your ride: engine and vehicle mods, gears, emission needs, driveablility desires, performance desires, etc. Be realistic: your DD cam-only isn't going to be a 9 second car for $400.
If your cam guy changes his specs for your custom cam because you didn't like his choice, try another guy, or just "design" your own and get it made. Then you will only have yourself to blame... or congratulate for the performance of your engine.
My $.02
My $.02
I am in the same boat as him, just trying to learn more, however I am letting my designer do what he thinks is the best. I just want to try and understand why he is doing what he is doing!!
Steve
My current cam for my 454 LS2 has 27.5*.
Actually the amount of TQ the motor produces at part throttle is as important as anything else, not just the overlap numbers. Plus if you have more gear, or a higher overdrive (like a 4L60 vs a M6) then you can stand more overlap in driving situations.
Add: I had a customer with a 400 cube LS motor and wanted more drivability, he didn't like the cookie cutter 242/248 deal but I swapped him over to a smaller cam with virtually the same overlap and he picked up TQ all the way to 5500rpm with the same HP level and drivability improved. The TQ improvement was 15-20rwhp from idle to TQ peak with the same peak HP numbers...
Bret
