Advanced Engineering Tech For the more hardcore LS1TECH residents
Peak Piston Speed?
Old Mar 29, 2008 | 09:39 AM
KCS's Avatar
KCS
Moderator
Default Peak Piston Speed?
Is there anyone out there with a formula for peak piston speed? I've searched and searched, speedtalk and eng-tips even.
Old Mar 29, 2008 | 09:53 AM
DanO's Avatar
lots of threads here about this topic... do a search.. Here are a few
(I went to "seach this forum" button and typed in "Piston speed")
https://ls1tech.com/forums/showthrea...t=speed+piston
Old Mar 29, 2008 | 06:33 PM
KCS's Avatar
KCS
Moderator
I appreciate the help, but I still don't see what I was looking for. Those links you provided spoke mainly of mean, or average, piston speed. I am looking for peak piston speed which I know involves somewhat complex algorithms. Thats what I am looking for.
The second link does contain an online calculator, which will have to do for now I guess.
Thanks though,
Kent
Old Mar 29, 2008 | 10:55 PM
405HP_Z06's Avatar
I'm not familiar with a formula for 'peak piston speed'. Piston speed is a variable number based on RPM and stroke. Here's the formula for Piston Speed in feet/minute.
Piston Speed (FPM)= (2 x Stroke (inches) x RPM) / 12
or
Piston Speed (FPM)= (Stroke (inches) x RPM) / 6
Could you be looking for Piston G's @ TDC?
Old Mar 30, 2008 | 12:05 AM
racer7088's Avatar
Thumbs up
Kent the speed talk deal had one with peak piston speed. You need to know rod length and stroke and rpm but it is usually around 70-78 degrees ATDC.
A 4 inch stroke and 6.125 rod have a Max / Mean Ratio of 1.65 so at 4000 FPM Mean piston speed you have a peak of 6600 FPM instantaneous piston speed. This is around 75 degrees ATDC again.
Old Mar 30, 2008 | 03:29 AM
405HP_Z06's Avatar
Okay, I understand what your looking for. Does this spreadsheet calculate what your looking for?
Spreadsheet
Old Mar 30, 2008 | 07:19 AM
Alvin's Avatar
I have the formula, its not that easy to type here with sin's and cosine.. Not sure what the best way to share it is...
If you can find a formula for piston position just take the derivative of it.. thats what I did
Old Apr 1, 2008 | 09:51 AM
383jake's Avatar
dont know if this helps, but.. stroke x RPM/ 6= average piston speed of feet per minute
Old Apr 1, 2008 | 10:05 AM
405HP_Z06's Avatar
See post #4
Old Apr 1, 2008 | 11:19 AM
383jake's Avatar
Originally Posted by 405HP_Z06
See post #4
i see it now... my bad
Old Apr 1, 2008 | 12:59 PM
405HP_Z06's Avatar
I calculate the peak piston speed to occur at 72 degrees for the parameters above. Trying to figure out what I did wrong, how did you arrive at 75 degrees?
Old Apr 1, 2008 | 01:00 PM
405HP_Z06's Avatar
No bad, it's all good.
Old Apr 1, 2008 | 05:20 PM
racer7088's Avatar
Thumbs up
405HP,
You are going to be right as that sheet I saw was only in 5 degree increments so you are closer and are probably right as well!
Old Apr 2, 2008 | 07:23 AM
KCS's Avatar
KCS
Moderator
Spreadsheet
Yeah, pretty much except I would like to know the actual formula before I have to rely on a spreadsheet. Thanks for the link though.
Old Apr 2, 2008 | 07:47 AM
405HP_Z06's Avatar
Here is a link that provides what your looking for. He designed the spreadsheet I posted earlier.
http://www.wfu.edu/~rollins/piston/
Old Apr 3, 2008 | 09:56 PM
405HP_Z06's Avatar
405HP,
Correction , I figured it wrong initially. It should be 73 degrees instead of 72 degrees.
Old Apr 27, 2008 | 04:56 AM
ProductionS14's Avatar
http://www.csgnetwork.com/pistonspeedcalc.html
