People who have Re-Upholastered Door Panels - Come In!
So when I was taking the plastic tabs I cut them way too short and now I don't have any tabs to put them cardboard/material back onto the door panel. Did anyone else run into this problem or have a suggestion?
I'm talking about the little plastic tabs that hold the cardboard onto to the door panel. I can't see these being sold anywhere as they are really just a little piece of melted plastic.
If the tabs will push back though the panel you can use some quick setting epoxy to fix it back together. Just push the panel down so the tab shows and put a glob of epoxy on it. Hold it till it dries. Move onto the next tab. keep going till they're all done.
I think I'm having such a problem because I put them vinyl on right over the carpet (I thought it looked better that way) so now the tabs have to get back threw the cardboard, carpet, and vinyl.
Do you think I'd be able to plastic weld on some studs and just push the stubs threw everything?
Copy & Paste Moderator
I put new silver cloth over the existing charcoal/black cloth. I don't remember the tabs being short though. Mine were long enough. I used a blob of LockTite Plastic Epoxy on each post and kept some pressure/weight on the panel to hold it together untill the epoxy hardened.
Here is the write-up I followed:
http://www.lastofthebreed.com/Instal.../DoorPanel.htm
(Except I used plactic epoxy instead of re-melting the tabs)
You can find pics of my results here:
http://www.fadingarrow.com/DoorPanels.htm
Those panels look great. Good job.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I guess you'll have to lengthen them somehow. If I remember correctly, some of them are hollow tubes. For those, you can probably use short/fat screws. As for the rest... there have been some good suggestions in here.
If you use a soldering iron for this, just remember that melting plastic generally stinks. Do it with good ventilation or outside. Also, don't use your good tip that you use for electronics soldering. Use an older tip you don't mind not being able to use again for electronics. The reason I say this is because the plastic can stick to the tip and leave a film (even if it looks fairly clean) that may not let it quite work well for electronic soldering and may contaminate solder.
Thanks.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
