how to make ta fog lights stay on w/ hi beam?
Old 02-06-2002, 09:23 PM
highgmc's Avatar
Default how to make ta fog lights stay on w/ hi beam?
isn't there some way to make my trans am's fog lights stay on when I turn the high beams on?
highgmc is offline
Old 02-06-2002, 09:26 PM
BIGBOS's Avatar
Default Re: how to make ta fog lights stay on w/ hi beam?
I'm sure there is, the fog lights really don't serve much of a purpose anyways...they don't make any light difference when you have the regular lights on....try flipping them on and off at night....you will see no change... <img src="gr_stretch.gif" border="0">
Why are you trying to blind people anyways... <img src="gr_eek2.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
BIGBOS is offline
Old 02-07-2002, 12:00 AM
Round Rock TA's Avatar
BIGBOS,
Maybe yours are broken. Mine make a difference.
Try to trace wires. If a standard Auto relay is uses find the wire that connects to the high beams and ground it. Maybe!
Round Rock TA is offline
Old 02-07-2002, 06:50 AM
Jax White TA's Avatar
Mine make a big difference too.
Jax White TA is offline
Old 02-07-2002, 10:18 PM
Paul Bruno's Avatar
This is one way we use to do it on the Grand Prix
The factory fog lights are wired to their own relay, except the ground wire is run through the high beam relay. When the brights come on the fogs are no longer grounded so they turn off.
Bend the ground plug on the relay up, connect a wire to it, then attach the other end of the wire to the car body somewhere.
[ February 07, 2002: Message edited by: Paul Bruno ]</p>
Paul Bruno is offline
Old 02-09-2002, 09:18 AM
Trans Am WS6 RGS's Avatar
Cut the light green wire!! I did that "mod" long ago. I will double check to make sure that its the light green wire (In your fuse box) so that you dont accidently cut the wrong wire.
Just look under the fuse box and there should be a bunch of wires down there. Cut the light green one and the ground it while taping off the other end, just so it doesnt get wet when it rains or when you wash your car.
Honestly the fog light dont do much but neither do the ones on other cars, then again they really arent fog light more as they are driving lights. Though I can notice the little bit of light when I flip them on and off.
Having all your lights on looks cool and that was the only reason I did it. That and to attempt tp blind those who blind me.
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Trans Am WS6 RGS is offline
Old 02-10-2002, 04:23 PM
SS 414's Avatar
I have my fog lights stay on with my high beams. I pulled the fog light relay, and replaced it with a wire. Here's a pic...
You can see the black wire I have in there. It makes the fog lights stay on anytime the lights are on. Low's, high's, and parking. Also when you lock and open the doors with the remote, the fog lights flash also.
SS 414 is offline
Old 02-10-2002, 09:22 PM
BIGBOS's Avatar
wheres the other end of that wire going to?
BIGBOS is offline
Old 02-10-2002, 11:07 PM
SS 414's Avatar
[quote]Originally posted by BIGBOS:
<strong>wheres the other end of that wire going to?</strong><hr></blockquote>
Sorry, should have explained a little more. When you pull the fog relay out, you will see there are 4 pin holes, where the pins on the fog relay went in. They are numbered, I don't remember the specific numbers off the top of my head. The wire is going from one hole into the other one. If I remember correctly, the holes you have to connect with the wire are #'s 1 & 8. But like I said, I don't remember off the top of my head. If we are looking at the picture from this frame of reference, the wire is going from the bottom left hole and the top right hole (on a diagonal). I'll look tomorrow if you want me to. It's dark out right now and pouring.
SS 414 is offline
Old 02-10-2002, 11:08 PM
SS 414's Avatar
Oh yeah, one more thing. This is on a 2000 Camaro. I belive it would be the same for a 99 T/A, or any other LS1 for that matter. I first tried the "cutting the green wire" mod, but that didn't work for me. Maybe there was a difference between the LT1 and LS1. So I soldered back the wire and just did what I posted above.
[ February 10, 2002: Message edited by: SS 414 ]</p>
SS 414 is offline
Old 02-11-2002, 06:20 PM
highgmc's Avatar
I just did mine! The top and bottom didn't work so I used both bottom ones (closest to the nose of the car) works great!
highgmc is offline
Old 02-11-2002, 06:37 PM
BIGBOS's Avatar
Terry did you use the the above method or did you cut the green wire....
And can someone tell me the # on the fuse so I know which one to yank out... <img src="gr_stretch.gif" border="0">
BIGBOS is offline
Old 02-11-2002, 07:06 PM
highgmc's Avatar
I just pulled out the fog light fuse and there is four pins on it, jumper the 2 front ones together (ones toward the nose of the car)
the fog light elay is in the fuse box under the hood and the fog light one is listed on top of the cover
highgmc is offline
Old 02-11-2002, 07:37 PM
Texas Director
mmiller's Avatar
I just did it too. Works perfect, just like Terry said. I used some solid #18 or #20 wire.
Does anyone know how to keep the low beams, high beams, and fog lights on at the same time?
mmiller is offline
Old 02-11-2002, 08:24 PM
Bobby C 01TA's Avatar
wow.. thanks for the tips.. i was wondering myself and someone got to it before me!
Bobby C 01TA is offline
Old 02-11-2002, 08:44 PM
highgmc's Avatar
ok guys here is another question.
Does anyone make brighter fog light bulbs?
highgmc is offline
Old 02-12-2002, 12:00 AM
SS 414's Avatar
[quote]Originally posted by mmiller:
<strong>I just did it too. Works perfect, just like Terry said. I used some solid #18 or #20 wire.
Does anyone know how to keep the low beams, high beams, and fog lights on at the same time?</strong><hr></blockquote>
High/Lows
Zurbo posted it, it is the 2nd to last post on the page
[ February 12, 2002: Message edited by: SS 414 ]</p>
SS 414 is offline
Old 02-14-2002, 09:51 AM
SloWhite's Avatar
[quote]Originally posted by terry99ta:
<strong>ok guys here is another question.
Does anyone make brighter fog light bulbs?</strong>
<hr></blockquote>
Go to www.prostreetlighting.com Look at the 893 Xenon bulbs. They are direct replacement for the stock 880s.
SloWhite is offline
Old 10-05-2002, 04:36 PM
Zurbo's Avatar
Just for reference, I've got the 4 beam brights and fogs with brights mods up on my website now.
*** dumped roadrunner so none of the picture links work in my older posts from ls1.com.
You can find the new mods page Here
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ October 05, 2002, 04:37 PM: Message edited by: Zurbo ]</small>
Zurbo is offline
Old 10-05-2002, 07:02 PM
Administrator
unit213's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zurbo:
<strong>Just for reference, I've got the 4 beam brights and fogs with brights mods up on my website now.
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Zurbo. I'm going to do this mod tomorrow by following your instructions.
Dan
unit213 is offline
Quick Reply: how to make ta fog lights stay on w/ hi beam?
