it's gettin' close!
just seen alot post up they get them and didnt know
cant wait to see the car finished
I just spent 3 hours of my only off day reading your build thread!
I cannot wait to see this thing come together. Drive it down to Alabama, us good ol' boys will show you some fun.
will do, man. i'm going as fast as i can afford to, there's a lot of "lay off talk" around the shop where i work, so i'm kind of getting less worried about the car and more about my livelyhood...BUT, on a more positive note, my new Moroso oil pan showed up today. It puts the Canton to shame as far as quality and appearance goes. i also went ahead and got the Remote filter mount as well, bringing the total to just a hair under $700 from Summit Racing for this f*%&ing oil pan. Granted, it came with a pickup & o-ring, windage tray, nuts i don't need, and STICKERS (
This pan is on its way to its new home, along with my ATI Super Damper and ARP balancer bolt, here's a few pics of the oil pan for the road...be sure to compare it to the other pics i posted of the Canton pan, i'll go ahead and take some side-by-side shots when i get out the my car. HOPEFULLY the next pics i post will be of a LSX 454 longblock sitting on a UMI K-member underneath a 2001 SOM SS....with Tick Performance level 3 T56 bolted up to it behind the Textralia ExoSkel triple disc clutch...
, if you're in the market, get with 99blancoSS. we did an ATI group purchase recently and he MAY be able to hook you up. i'm pretty sure there were a couple pullies left over but i'm not sure which.
Moroso
Better welds, construction, and overall design. CNC'd mounting flange. Needed an extra hold drilled on the mounting flange (last 2 pics above) and doesn't have a place for the oil level sensor. BIG BONUS: Windage tray only needed holes reamed to accomodate ARP studs and two washers for clearence, Oil pickup tube only needed same modification. Pickup to pan clearance was perfect out of the box, dead nuts on .290" (should be .250"-.300"). Also has magnetic drain plug and came with bigger sticker
Canton
Flimsy mounting flange, did not include windage tray or pickup. Welds good, but lacking visual appeal. Nice baffle design, all holes and sensor provisions accounted for. Price reflects what you get for your money with BOTH oil pans.
EDIT: After looking at the pictures, the Canton pan would also need a bolt hole drilled OR my LSX block and factory gasket have one extra hole...in the same place. i didn't have a stock pan to verify.
i'm trying!!!
