it's gettin' close!
youre car is gorgeous and its gonna haul some ***. im actually not in st louis, im out about 20-30 miles away in st peters, far enough away from all that trash downtown. its real nice out here. if i actually lived in st louis or the immeadiate metro area, well, i wouldnt try to own a nice car or any nice things, if ya know what i mean. and id be packin The Best V8 Stories One Small Block at Time
Front end is now loosely assembled. i'm still waiting on the right strut mounts to come in. i got them both a couple days ago, but the hardware on them didn't match. One (pictured) has gold-anodized studs and the other side had black oxide coated studs that were 1/4" shorter than the other side. Normally i wouldn't care, but in case you didn't notice, the car is kind of a show car, so i didn't want different color/length studs stcking through the fender wells. I re-ordered the driver's side mount, and it showed up in black just like the first one. SO...my guy at O'reilly's ordered 5 mounts from their KC store hoping at least one will be gold. Those won't be here until wednesday it seems.
I managed to get the upper A-arm mounts painted, they were forgotten when it came time to go to the powdercoater, but you can't see them anyway so whatever. The steering rod holes in the spindles got drilled out to the necessary 1/2" to accomodate the bolts supplied with the BMR rack.
I'm going fishing today, but will possibly do a little more work on the car tonight. If i do, i'll post pictures as usual...
Tried to work on it a bit last night, ended up making 3 trips into town for little parts and upper ball joints...which were $107 for the pair
All i really ended up doing was put the upper A-arm on one side, adjust the coilover up a bit, and decided to re-powdercoat my calipers before i put it all together....BUT progress was made. Tomorrow my driver's side strut mount SHOULD be here so i'll button up the front end, minus the brake calipers that will be off to the powdercoater.
i knew that was going to be pointed out...thought it would have taken longer. Thanks, man
I guess i'll go ahead and paint them. I WOULD have had them powdercoated, but i didn't see any way to pull the electronics out easily/safely....
Edit: I'm overly jealous of how clean your car is. If I had a garage my car would totally be apart for a "restoration". My OCD would be in overdrive.
