Anyone painted there gauge pods to match stock.
Old 01-26-2009 | 06:06 PM
tasilver's Avatar
Default Anyone painted there gauge pods to match stock.
Well I have everything I need to do my project this weekend. I have the new dash pad (mine cracked), duel Aeroforce guages, and double gauge pillar replacement. My problem is that the pillar is black. Has anyone painted theres to match the rest of inside abs pieces? If so what color (name) should I look for. Thanks for any help.
Old 01-27-2009 | 12:50 PM
tasilver's Avatar
OK, I went picked up the paint. Turns out the duplicolor bumper paint is an exact match. I used a piece of dash pad to match the cap color. I will paint it this weekend and post pics since there is hardly any info about this on the board. As along as the paint is the same color as the cap everything should match.
Old 01-27-2009 | 08:40 PM
mattl31's Avatar
let us know how that works for you man. i know there is a company called SEM that sells interior matched paints but it has to be special ordered. that would be great if something you can get locally matches. i've been wanting a triple pillar pod and this is part of the reason I havent done it yet.
Old 01-27-2009 | 10:22 PM
f-bodyguy's Avatar
yes please do i wanna see pics
Old 01-27-2009 | 10:24 PM
98 WS6's Avatar
When I bought my gauge pod from Summit Racing it had "suggested items" and they were interior-matched paint for interior colors of my model. I didn't paint it though, you barely even notice the difference
Old 01-28-2009 | 07:20 AM
tasilver's Avatar
Yeah I will post pics. I search the forum and found little info. I am going to try to paint it today if I get a chance. If not, I know what I will be doing Saturday. I guess it depends on who made the pillar if it is close or not in color. My pillar is jet black and the rest of the trim in my car is charcoal, it is not close in color.
Old 01-28-2009 | 08:59 AM
LS1nut377's Avatar
+1 for pics cant wait to see
Old 01-28-2009 | 06:29 PM
98 WS6's Avatar
That's how mine is, but I didn't paint it and it looks fine lol.
Let us see it when your done! So lucky you got those gauges haha.
Old 01-28-2009 | 06:39 PM
Al 96 Ram Air T/A's Avatar
You mean like this?
Sorry about the poor shots. The car is apart waiting for it's new cluster to arrive.
I used SEM Graphite...matched perfectly to my 96 graphite interior. I blended the pod into the A-pillar using fiberglass and body filler. Looks like it came from the factory.
Old 01-28-2009 | 06:48 PM
98 WS6's Avatar
How long did it take you to blend it in? Was it difficult? and last but not least did you do it in the car or take everything off?
Old 01-28-2009 | 07:36 PM
tasilver's Avatar
OK guys I think I have a match. Only one problem. My vent ring is smaller than the hole for it on the pillar. Seems like I can't win. I will figure somthing out.
Anyway here is the pic of the stock vent ring and the pillar I painted.
I used the adhesion spray and duplicolor bumper paint both rattle cans. I will post the exact color tommorow I left the cans at work. I very happy with the match.
Old 01-28-2009 | 08:03 PM
Took a couple of days between coats to dry. It's not that hard. Blend it in with layers (thin) of Bondo. Sand smooth.
I used all of SEMs products...start to finish.
You have to do this out of the car. I can't imagine how you could do it in the car
Old 01-29-2009 | 07:28 AM
tasilver's Avatar
Here is the name of the paint I used and sku number off of the advanced auto part reciept.
duplicolor bumper coating pnt flex bmprct blk 11 7170909
duplicolor adhesion promoter pnt adhesion prmtr 11 0 7140919
Hope this helps anyone who wants match there gauge pod to stock.
Old 01-29-2009 | 07:50 AM
RsSean's Avatar
I may have to go look for that. It looks kinda brown in the pics? I thought you said the interior was charcol?
Old 01-29-2009 | 01:17 PM
c0ncEpT's Avatar
The previous owner of my pod painted it.
These are some pics when it was still in his possession
Before
After
Old 01-29-2009 | 02:45 PM
Photochop's Avatar
I used SEM plastic bond spray stuff/adhestion premotor and the SEM dark graphite/gray color on my A-pillar and it matched perfectly to my '98 Z28 dash/trim. It was real easy, just clean the pillar with rubbing alcohol, make sure its good and dry, and then spray the plastic bond stuff on it, and the gray paint right after. Dried to the touch in about 5-10 mins and has help up great. I'll try and find a good pic of it.
Old 01-29-2009 | 04:18 PM
hlaalu's Avatar
i just lightly sanded mine to take away some of the shine it had. other then that, the color matched pretty well.
Old 01-29-2009 | 04:31 PM
98 WS6's Avatar
Lol I know, I don't even know why i asked that. My only concern with blending it, is what if one of the wires falls out or your have to get behind the gauge, or if you upgrade. Then what
Old 01-29-2009 | 06:13 PM
After the pod is attached, you have to cut holes in the back of the A-pillar so you can access the wires. I basically cut out nearly all of the A-pillar to get my fat-fingers in there to attach the itty-bitty nuts onto the gauge brackets. The other issue is connecting the tiny wires to the gauge.
Without a doubt, that was the hardest part.
